  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • ParkerP
    ParkerP
    i was going to comment about apex seals... but i figured i would give him a chance to tell his story... lol
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • MisterCMKM
      MisterCMKM
      thrash;315544 wrote:
      Ford is back :)
      • MisterCMKM
        MisterCMKM
        I think that motor was supposed to go in there. Except for the oil pressure sender. 😄
        Ford is back :)
        • ParkerP
          ParkerP
          having to take off the brake booser to get to the oil pressure sender FTMFL....
          • zbrownZ
            zbrownZ
            just get rid of that thing!
            • B
              B
              just a bad ignition amplifier (AEM). wasn't sparking my shit.
              • T
                T
                tqisking
                Looks good.
                2 things
                #1 that 90 after your regulator is horrible for flow
                #2 the coil is supposed to be mounted vertical not horizontal..
                other than that it looks good..:)
                • MisterCMKM
                  MisterCMKM
                  tqisking;207648 wrote:
                  Looks good.
                  2 things
                  Good call on the coil mount. The high vibration coil can be mounted in any position. I would have never thought of that.
                  Ford is back :)
                  • T
                    T
                    tqisking
                    Not sure if you were being sarcastic or not so here is some proof....and if you were not never mind 😄
                    http://www.msdignition.com/forum/showpost.php?p=43998&postcount=4
                    msdtechsupport3
                    Tech Support Join Date: Feb 2006
                    That's a good point. I forgot to ask you if the Blaster 2 coil was mounted vertically or horizontally. Especially with an MSD Ignition box we recommend mounting this, or any other oil filled coil, vertically with the tower pointing upward so that the internal windings remain submurged in the cooling oil.
                    MSD Tech Support
                    915-855-7123
                    • MisterCMKM
                      MisterCMKM
                      Nope, not being sarcastic.
                      Ford is back :)
                      • ParkerP
                        ParkerP
                        coil is just sitting like that for now.... i need to drill another hole to mount it and go caught up in other shit..... and im not too worried about the 90 degree... fuel line is plenty big... if i have a starving issue... then ill replace it...
                        if it makes you sleep better ill replace it.... maybe
                        • MisterCMKM
                          MisterCMKM
                          liar
                          Ford is back :)
                          • T
                            T
                            tqisking
                            Yea your right.....I do not know anything..
                            I try to help a guy out and this is what you get...
                            You could have 10 right angles in the fuel system I could really care less, I was just pointing out a potential problem just like the coil but I guess you know it all.....
                            • ruthless351R
                              ruthless351R
                              ruthless351
                              simma down now!!
                              1. maybe you could of worded that differently. You come across as a know it all.
                              2. Its teh internets! 🙂
                              • MisterCMKM
                                MisterCMKM
                                dude, lighten up. He didn't mean anything as a shot at you.
                                Ford is back :)
                                • ParkerP
                                  ParkerP
                                  i really didnt mean anything by it, i was just in a hurry and replied quick to your post... you actually reminded me to turn the coil up right. i didnt mean to come off as a dick... just in a hurry...
                                  on a completly side note the car ran tonight, i think i need to ground my ingition box better because after a few starts the led on the box started flashing and it would not fire.... time to do some research
                                  • ParkerP
                                    ParkerP
                                    re grounded the ignition box and she fired right up 🙂
                                    • RexwagonR
                                      RexwagonR
                                      so whens it going to be on the street? we should have a little meet at tintmaster when it actually stays above 35 degrees.
                                      • B
                                        B
                                        congrats man.
                                        • ParkerP
                                          ParkerP
                                          i was shitting my pants last night when it wouldnt fire up anymore... so i just did some research got some sleep and now its AOK 🙂
