  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • ParkerP
    ParkerP
    buicks are cool:smileyR::icon_puke_r:
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • ParkerP
      ParkerP
      coming along
      • MisterCMKM
        MisterCMKM
        weak...
        Shoulda done a SBF
        thrash;315544 wrote:
        Ford is back :)
        • ParkerP
          ParkerP
          MisterCMK;206852 wrote:
          weak...
          Shoulda done a SBF
          OR, i could just throw my money in a bucket and light it on fire..... would have been a better use for it...
          • zbrownZ
            zbrownZ
            haha
            bucket fires are fun though
            • B
              B
              looks bad ass man! finally got mine running right again. got her cleaned up and gona do a photoshoot of her. I'll post it up later tonight or tomorrow.
              • ParkerP
                ParkerP
                what was wrong with it?
                • JoelJ
                  JoelJ
                  It still have no pistons... duh!
                  • ParkerP
                    ParkerP
                    i was going to comment about apex seals... but i figured i would give him a chance to tell his story... lol
                    • MisterCMKM
                      MisterCMKM
                      Ford is back :)
                      • MisterCMKM
                        MisterCMKM
                        I think that motor was supposed to go in there. Except for the oil pressure sender. 😄
                        Ford is back :)
                        • ParkerP
                          ParkerP
                          having to take off the brake booser to get to the oil pressure sender FTMFL....
                          • zbrownZ
                            zbrownZ
                            just get rid of that thing!
                            • B
                              B
                              just a bad ignition amplifier (AEM). wasn't sparking my shit.
                              • T
                                T
                                tqisking
                                Looks good.
                                2 things
                                #1 that 90 after your regulator is horrible for flow
                                #2 the coil is supposed to be mounted vertical not horizontal..
                                other than that it looks good..:)
                                • MisterCMKM
                                  MisterCMKM
                                  tqisking;207648 wrote:
                                  Looks good.
                                  2 things
                                  Good call on the coil mount. The high vibration coil can be mounted in any position. I would have never thought of that.
                                  Ford is back :)
                                  • T
                                    T
                                    tqisking
                                    Not sure if you were being sarcastic or not so here is some proof....and if you were not never mind 😄
                                    http://www.msdignition.com/forum/showpost.php?p=43998&postcount=4
                                    msdtechsupport3
                                    Tech Support Join Date: Feb 2006
                                    That's a good point. I forgot to ask you if the Blaster 2 coil was mounted vertically or horizontally. Especially with an MSD Ignition box we recommend mounting this, or any other oil filled coil, vertically with the tower pointing upward so that the internal windings remain submurged in the cooling oil.
                                    MSD Tech Support
                                    915-855-7123
                                    • MisterCMKM
                                      MisterCMKM
                                      Nope, not being sarcastic.
                                      Ford is back :)
                                      • ParkerP
                                        ParkerP
                                        coil is just sitting like that for now.... i need to drill another hole to mount it and go caught up in other shit..... and im not too worried about the 90 degree... fuel line is plenty big... if i have a starving issue... then ill replace it...
                                        if it makes you sleep better ill replace it.... maybe
                                        • MisterCMKM
                                          MisterCMKM
                                          liar
                                          Ford is back :)
