its almost....
tqisking;207648 wrote:
Looks good.2 things
#1 that 90 after your regulator is horrible for flow
#2 the coil is supposed to be mounted vertical not horizontal..
other than that it looks good..:)
Good call on the coil mount. The high vibration coil can be mounted in any position. I would have never thought of that.
Not sure if you were being sarcastic or not so here is some proof....and if you were not never mind
http://www.msdignition.com/forum/showpost.php?p=43998&postcount=4
msdtechsupport3
Tech Support Join Date: Feb 2006
That's a good point. I forgot to ask you if the Blaster 2 coil was mounted vertically or horizontally. Especially with an MSD Ignition box we recommend mounting this, or any other oil filled coil, vertically with the tower pointing upward so that the internal windings remain submurged in the cooling oil.
MSD Tech Support
915-855-7123 -
coil is just sitting like that for now.... i need to drill another hole to mount it and go caught up in other shit..... and im not too worried about the 90 degree... fuel line is plenty big... if i have a starving issue... then ill replace it...
if it makes you sleep better ill replace it.... maybe
Yea your right.....I do not know anything..
I try to help a guy out and this is what you get...
You could have 10 right angles in the fuel system I could really care less, I was just pointing out a potential problem just like the coil but I guess you know it all.....
simma down now!!
maybe you could of worded that differently. You come across as a know it all.
Its teh internets!
tqisking;207856 wrote:
Yea your right.....I do not know anything..I try to help a guy out and this is what you get...
dude, lighten up. He didn't mean anything as a shot at you.
