  3. Run Your Mouth
  4. Swap.........avi?
Swap.........avi?
80 Posts 15 Posters 7.6k Views
  • ParkerP Offline
    ParkerP Offline
    Parker
    KidSupreme;206607 wrote:
    Rotaries make me scared.
    because they break!!... OH SNAP!!!! yeah i said it
    10 Jeep
    10 F450
    08 F250
    05 F350
    86 rx7
    70 F100
    63 Olds
    > BlueSRT0483;244555 wrote:
    > Trafik Jamz;260984 wrote:
    > You are right Parker.
    • ParkerP Offline
      ParkerP Offline
      Parker
      http://www.monstermiata.com/Monster_V8_Kit.asp
      10 Jeep
      10 F450
      08 F250
      05 F350
      86 rx7
      70 F100
      63 Olds
      • ParkerP Offline
        ParkerP Offline
        Parker
        do you know anything about complicated engine swaps? <u>[U]OR</u>[/U] we could just ask what do you know?.... that seems like a better place to start... because from what i have read so far... you like to over complicate things... there are kits out there for a 2.3, and if people are swapping the 5.0 into them in sure a 2.3 would fit... and in a case like this you dont reprogram the miata ECU... you make a wiring harness to fit the 2.3 ECU( not that hard) and make it work with the swap car ( reprograming, resistors, you get the point)... comments? i can do this all day... so please, at least do a google search before you reply, and inform yourself about these sortof swaps so i dont have to point out the obvious... as you clearly need done...
        10 Jeep
        10 F450
        08 F250
        05 F350
        86 rx7
        70 F100
        63 Olds
        • ParkerP Offline
          ParkerP Offline
          Parker
          weshole;206559 wrote:
          What, swapping a SBC into a 7 is different? That's soooo 15 years ago. I'll give ya this.. you went with some nice go fast parts but originality........:rolleyes:
          you make me lol
          10 Jeep
          10 F450
          08 F250
          05 F350
          86 rx7
          70 F100
          63 Olds
          • zbrownZ Offline
            zbrownZ Offline
            Man you lie..... that has never ever happened
            :icon_scratch:
            rx7-8.89@157mph
            12v dodge, twins
              A lil off topic (imagine that).... But Parker, what rear diff are you running in the 7?
                Parker;206623 wrote:
                do you know anything about complicated engine swaps? <u><u>OR</u></u> we could just ask what do you know?.... that seems like a better place to start... because from what i have read so far... you like to over complicate things... there are kits out there for a 2.3, and if people are swapping the 5.0 into them in sure a 2.3 would fit... and in a case like this you dont reprogram the miata ECU... you make a wiring harness to fit the 2.3 ECU( not that hard) and make it work with the swap car ( reprograming, resistors, you get the point)... comments? i can do this all day... so please, at least do a google search before you reply, and inform yourself about these sortof swaps so i dont have to point out the obvious... as you clearly need done...
                was this projected at me or the nooby... If so I know that there are kits for v8's, and I know people do 2.3's, but there is no need for these swaps other than shock factor of opening your hood. A LSx or a 302 isn't a wise choice, IMHO, To compliment the miata's inteded pusposes.... Altho a tube fram miata dragster with a beefy v8 in it would be sweet, or you could go with a 6 liter jag v12 like brainsboy on Miata.net...
                http://forum.miata.net/vb/showthread.php?t=258649
                  Joel I do belive your wrong about the LSx swap. Those engines are nearly the same weight as the 1.6 in there. You loose nearly none of the cars handling capabilities. They are just an expensive and involved swap to do properly. So it's not for the faint of heart.
                  • ParkerP Offline
                    ParkerP Offline
                    Parker
                    oops forgot to hit the "quote message in reply" it was projected at LupusSingularis
                    10 Jeep
                    10 F450
                    08 F250
                    05 F350
                    86 rx7
                    70 F100
                    63 Olds
                    • ParkerP Offline
                      ParkerP Offline
                      Parker
                      im using the stock one till the kinks are worked out of it... but by mid summer i will have a ford 8.8 in it... then comes a trans brake and some giggle juice 🙂
                      10 Jeep
                      10 F450
                      08 F250
                      05 F350
                      86 rx7
                      70 F100
                      63 Olds
                        Soild axle or IRS out of a thunderbird?
                        • ParkerP Offline
                          ParkerP Offline
                          Parker
                          solid.... not going to fuck around with another weak IRS...
                          10 Jeep
                          10 F450
                          08 F250
                          05 F350
                          86 rx7
                          70 F100
                          63 Olds
                            You're not gonna kill the 8.8 IRS out of the Thunderbird. They hold up tp the best that the best LS1-2 throws at it. And...... IT HANDLES with it.
                              I never said anything about how much the motor weighs, wes. The fact is, the miata is a quick, Nimble car. I guess 300 ft/lbs of torque doesn't strike me as nimble. With a turbo setup, you aren't always in boost, there for you can still take a corner at a decent amount of throttle without killing yourself. I guess I might just be a n00b driver but thats the way I see it. I would love to have the power of a v8 without having to go forced induction, I don't have the knowledge or the deep pockets needed for doing it properly. I guess my car won't be a monster miata...
                                A quick car? The MIATA? I think not. It IS a fun spirited car to drive because it is so light. But 300 ft lbs as you refer to it is only 300 ft lbs when you decide to use it. I'd rather have the option of having the power and deciding NOT to use than watching whomever go right by. I'm speaking from having one for almost 4 years now. You'll see when you get more wheel time. OF course you may be comparing it to previous cars you have owned. Then it may seem like a supercar. You can only justify the cars handling prowess and power to weight ratio so much.
                                • LupusSingularisL Offline
                                  LupusSingularis
                                  If you ask any Ford gearhead about swapping a 5.0 into a 2.3 foxbody, they'll tell you the cheapest and best way to do is to plain trade in the 2.3 and buy a stock 5.0.
                                  The Ford K-member was designed to accept both the 2.3 mounts and the 5.0 mounts.... if you get a k-member just for swapping the 5.0 into the miata you'll probly run into some major issues with getting the 2.3 mounted. The wireharnesses between a 2.3 and 5.0 are completely different, to the point that some of the pin-outs are different. The fuel line connections are on opposite sides of the engine.
                                  The Monster Miata kit isn't gonna be much help for this one. You'll still find that you need a lot of custom work and that the usual kits aren't going to help much at all
                                  ...and don't even get me started on if your donor car had a TFI ignition system.. even the Ford guys are ashamed of that one (especially if the resistor gel overheated, leaked and started the module on fire). :eek: I know you would use the miata ignition, but who knows what issues you might run into with spark plugs and grounds and general wiring, the TFI had super-high risistance on one end in the modules and super-low resistance on the other end to cope with it.
                                  I didn't know there were kits for dropping a 5.0 into a miata.. that swap is kind of frightening.. kewl though :woot:
                                  Every time that someone says "I don't believe in Ricers." Somewhere, there's a Ricer that drops to the ground, DEAD.
                                    LupusSingularis
                                    And a Thunderbird 8.8 IRS is a pretty rock-solid rearend, and one of the reasons that a thunderbird can handle just as well as mustang of the same year, despite the car being 500lbs heavier
                                      If you want to make it slower stick a B16 in that pig!
                                      • capitljC Offline
                                        capitljC Offline
                                        capitlj
                                        A 2.3 turbo would be a good motor for a Miata and the swap can't be any more difficult than stuffing an LSx into an FD, and a lot of fools have done that one. Just an fyi, for a donor motor getting one from a 82-88 thunderbird turbocoupe or a cougar XR7 would probibly be a lot cheaper than the SVO.
                                        > Mitch Hedberg wrote:
                                        2004 Impala LS 3.8
                                        • ParkerP Offline
                                          ParkerP Offline
                                          Parker
                                          theres a kit for the solid axle... bolts in, nuff said... if someone made a complete kit for the IRS 8.8 i would buy that.... but theres not... so im not going to fuck with it.... the car will handle just fine with a solid axle in it...
                                          10 Jeep
                                          10 F450
                                          08 F250
                                          05 F350
                                          86 rx7
                                          70 F100
                                          63 Olds
