  4. Guage install help.
Guage install help.
41 Posts 13 Posters 3.5k Views
    You cannot just splice into the wires. You can t the sender off of the back of the block though. 1/8 NTP -> -4AN adapter threads into the back of the block where the dummy light sender threads in, then run a 6" -4AN line up to a brass T. Then off of the brass t you will have the stock dummy light sender on one side, and the autometer sender on the other side. I cannot remember if you have to do something similar for the water temp or not...
