  4. Guage install help.
Guage install help.
41 Posts 13 Posters 3.5k Views
    mwc1 wrote:
    only you would do that jim!
    I am sure everyone has had there Twist and Tape Days of elecrical wiring.
      i know i was just joking around.
      • harwood39H Offline
        harwood39H Offline
        harwood39
        This is actually a very smart way to wire the guages. This will have them light up when i turn the ignition on, it will have them hooked in parallel power wise and requires less running of wires under the dash which equals less mess.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
          You know there will be a difference in power delivered to the when running in parallel.
          Read up on ohm's law before killing your car
          • 9 Offline
            9 Offline
            92TSIpos
            All the guages will be at a different brightness. the first guage wired will be brighter than the last guage wired, since all the other guages are using the power.
              thats only in series...parallel gets the same voltage for each load
              • 9 Offline
                9 Offline
                92TSIpos
                Look at his diagram, the guage on the right will get more power than the guage on the left.
                    alls i can say is i had my gauges hooked up like that once...then one day my car started smoking from my volts gauge..and they all stoped working...all my wiring melted.
                          harwood39H Offline
                          harwood39
                          Actually i set the diagram up in parallel, with series i would have to take the groun off the first one and connect it to the power on the next and so on. the way they are connected is like taking one wire and splicing seperate wires off of it to connect the power to the guages. same with the ground.
                          Fargo, ND 58103
                          701-429-3686
                          • treimcheT Offline
                            treimcheT Offline
                            treimche
                            To power up the gauges and the lights on the gauges, you should use a bigger gauge wire than what is supplied just to be on the safe side. Use maybe a 14ga wire for the ignition and ground and then tap off of those for the 4 seperate gauges. And please use solder and tape.
                            Troy
                            2009 Yamaha R1
                            2002 WRX
                            2001 Toyota Tundra
                            2001 Yamaha R6
                            1988 Yamaha YSR 50
                            2003 XR50
                              harwood39H Offline
                              harwood39
                              i didnt get any wire suplied, i didnt buy the instal kit, i planned on using good wire. I will most likely be using 12ga. i will be using solder, but i am using shrink tubing instead of tape.
                              Fargo, ND 58103
                              701-429-3686
                                use shrink tube and tape....trust me.
                                • treimcheT Offline
                                  treimcheT Offline
                                  treimche
                                  Heat shrink is very good. But then again there is nothing wrong with electrical tape either.
                                  Troy
                                  2009 Yamaha R1
                                  2002 WRX
                                  2001 Toyota Tundra
                                  2001 Yamaha R6
                                  1988 Yamaha YSR 50
                                  2003 XR50
                                    pin
                                    I now use heat shrink tubing and electrical tape since a clean connection is the most important thing with wiring. The heat shrink tubing doesn't make a perfect seal against the elements, and using tape alone can come apart. I picked up the most expensive model of 3M black electrical tape and it's rated for a wide range of temperatures.
                                    Barry
                                      Super 33 from 3m is what normally use, and pin is right, to get a really good seal it's a good idea to do both.
                                        Also make sure you use autometer's sending units.
                                          harwood39H Offline
                                          harwood39
                                          i want the stock guage for water temp to work tho, and the warning light for the oil preasure to work also. so i take it i cant just plice into the wiring harness? Thats what every one on honda-tech told me i could do.
                                          Fargo, ND 58103
                                          701-429-3686
