  4. Guage install help.
Guage install help.
41 Posts 13 Posters 3.5k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    Mine were cheap
    I paid $100 for my Oil preasure, a/f, and volt. water temp was $55. but i baught tuftes pod out of the hatch and am installing it in my civic so i need them to fill in the holes, plus they look better than nothing.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      harwood39H Offline
      harwood39
      Some people on honda-tech told me i can just splice into the existing harness for the water temp, and oil preasure sending units and dont have to replace the sensors.
      Fargo, ND 58103
      701-429-3686
        harwood39H Offline
        harwood39
        Ok, this is what i found out on ht.
        Air/Fuel ---> Black wire: Any ground Red Wire: Thick red wire or thick black with yellow stripe on 3 prong conector for ignition Purple: Thick solid white wire on the middle conector of the ecu.
        Oil Preasure ---> Tap into the existing harness and black and red are the same.
        Water Temp ---> Tap into existing harness and black and red are the same
        Volt ---> black wire: neg on battery, red to ignition.
        Fargo, ND 58103
        701-429-3686
          harwood39H Offline
          harwood39
          here is my wiring diagram i made.
          Fargo, ND 58103
          701-429-3686
            dont start a fire...
              do not wire it ghetto....mine was wired ghetto and everything was fucked up.........starts fires right jim!
                LOL true dat. Make sure you dont cut corners and use the right gauge wire for the current you are putting through it.
                  I know about starting your dash on fire. Its not cool.
                  I ghetto wired all of my street glow, my neons and shit back in the day and as I drove to the twin citeis the shit started on fire, iw as like OMG and i pulled off, and had to un hook everything. Not a big fire, but there was smoke, and the speaker wire i twisted togther was shot.
                  Just a headsup harwood.
                    only you would do that jim!
                      I am sure everyone has had there Twist and Tape Days of elecrical wiring.
                        i know i was just joking around.
                          harwood39H Offline
                          harwood39
                          This is actually a very smart way to wire the guages. This will have them light up when i turn the ignition on, it will have them hooked in parallel power wise and requires less running of wires under the dash which equals less mess.
                          Fargo, ND 58103
                          701-429-3686
                            You know there will be a difference in power delivered to the when running in parallel.
                            Read up on ohm's law before killing your car
                            • 9 Offline
                              9 Offline
                              92TSIpos
                              All the guages will be at a different brightness. the first guage wired will be brighter than the last guage wired, since all the other guages are using the power.
                                thats only in series...parallel gets the same voltage for each load
                                • 9 Offline
                                  9 Offline
                                  92TSIpos
                                  Look at his diagram, the guage on the right will get more power than the guage on the left.
                                      alls i can say is i had my gauges hooked up like that once...then one day my car started smoking from my volts gauge..and they all stoped working...all my wiring melted.
