  4. Project: putting a real motor in a RX-7
79 Posts 24 Posters 3.9k Views
    btleier;219949 wrote:
    how cheap are parts for motor?
    WAAAAYYYYY Cheaper. Not that it matters... They are very stout engines. They also weigh very close if not, less than a rotary. (That's what I read)
    • zbrownZ Offline
      zbrownZ Offline
      MisterCMK;219947 wrote:
      How big are the injectors?
      60#
      not as cheap as Gen I-II stuff.... but not ridiculous
      I will do a run down list of what i have paid sometime.....lets put it this way
      I have sold most of my rotary stuff..... and with that money i have not spent a penny more on anything for this setup thus far.........
      these engines will do 600 wheel stock so that is very stout for an engine with cast parts
      I have an iron block... so around 80lbs heavier than the alum. ls1/ls2 engines
      but I feel well worth it for the durability gained..... heck GM doesnt recommend boring the alum. blocks .010"+ over because of the thin liners........ where as the iron 4.8/5.3 blocks can be bored .100" over
      Since all the genIII-IV engines share the same cylinder spacing it is only common sense that the smaller bore versions are going to have thicker cylinder walls and inherently more strength with boosted applications
      IMO alum. blocks are overated...my car is a lightweight anyway...80lbs... bigdeal
      ya rambling again
      rx7-8.89@157mph
      12v dodge, twins
      • zbrownZ Offline
        zbrownZ Offline
        had lots of time today
        got the pushrods back in, intake, TB, elbow all done
        and got the harness perty much whipped
        but good news...
        cranked it over till i got 40psi cranking...... had good spark and could hear the injectors, so my harness is good to go 🙂
        missing some fittings to hook up my fuel supply, but a little carb cleaner down the hole and she fired to life ..... so good news, darn excited, different sound that is for sure
        anyway here is what came out of the stock harness
        pic of accomplishments today
        and hood clearance or lack of for those curious, and squawsnatch playing with himself
        rx7-8.89@157mph
        12v dodge, twins
          Just reuse your sticky scoop haha.
          • ChristianC Offline
            ChristianC Offline
            Christian
            Nice progress! Mine just started yesterday what a good feeling!
            Playtime Performance
            93 Mustang 6.0l ... 9.99 @ 136
            06 F-150 Lariat
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              91nbtsi
              Looking good!! Can't wait to see it with some snails...
              [email protected] -- DSM
              07 Mega Cab 5.9 CTD
                So...... you are going to have to make 3 holes in the hood on this one??????
                • zbrownZ Offline
                  zbrownZ Offline
                  so lots of progress..
                  perty much done with the NA stage.... see what it will do NA and then time for turbos
                  hmm what to list
                  temporary exhaust dumps till turbo time
                  sexy alt relocation setup
                  lots of other stuff.....
                  all it needs is a shifter, and some tunning
                  anywho it runs..... great 🙂
                  and short walk around vid (crappy)
                  http://www.youtube.com/watch?v=gPlGAXpRec4
                  rx7-8.89@157mph
                  12v dodge, twins
                    nice! glade to see it running!
                      Looks sweet. Whats all done to the motor again? Just stock NA?
