  4. Car Updates / Progress
  5. New project
New project
336 Posts 43 Posters 54.7k Views
  • capitljC
    capitljC
    capitlj
    bubba;272403 wrote:
    lol, half the hondas i've seen around wont even pass...
    And none of them would be competitive.
    Mitch Hedberg wrote:
    2004 Impala LS 3.8
    • XJHEADX
      XJHEADX
      XJHEAD
      weshole;272463 wrote:
      Huffers paradise. Impeccable organizational skills you fellas have.
      You can't say you guys, that would be just me....
      7.64 @ 187 3400 lbs. on KORN
      TTSBF
      RTCTTFMF PTOSITW
      • GrrG
        GrrG
        Grr
        ha, yeah my car is like that too, once its on the ground theres plenty of clearance. That aluminum is tricky isnt it! now and then ill be cruising along nice, then BAM, big ass hole in it
        2006 Trailblazer SS- my DD
        • XJHEADX
          XJHEADX
          XJHEAD
          Yanked the mock-up motor last night and pulled the tranny. The tranny will be dropped off at T-N-T Tranmission on Monday just to be checked out. Ted does a hell of a job. Had him do the re-build last summer right after P-10. Had a few runs on it then had it out for other things and he told me to bring it over just so he could take a look. Tore it down, everything looked good, so I put it back in. Figured it was out now so I would have him take another peak at it. Anyways the motor should be ready to be picked up early next week. Still have a lot of wiring to do and some suspension changes yet. I still haven't decided if I am going to change gears or not. Either I'll keep the 3.27's in it or put some 3.08's in it. I did make a custom Tranny crossmember for it the other night. I couldn't get my little Miller 135 to get very good penetration so I dropped it off over to 63Vette for a little tig action.
          Built with a cutting torch and a BFH
          TTSBF
          RTCTTFMF PTOSITW
          • XJHEADX
            XJHEADX
            XJHEAD
            Got the motor back last night. Hopefully start bolting some stuff to it in the coming days.
            Had them stuff some Oliver rods in it, they must have been a little beefier than the Eagles, it took 4 slugs of heavy metal.
            TTSBF
            RTCTTFMF PTOSITW
            • zbrownZ
              zbrownZ
              looks great........ holy F those valve covers seem tall
              rx7-8.89@157mph
              12v dodge, twins
              • z31Z
                z31Z
                z31
                Looks good. :icon_cheers: Did you make the oil pan?
                • C
                  C
                  Cobra Rob
                  As a trained welder you guys look like you know what you are doing
                  • XJHEADX
                    XJHEADX
                    XJHEAD
                    I made it black.. It is a Canton piece "of shit". Another thing that takes a hammer to make fit. Any manufacturer that says bolt-on is a liar.
                    One of us maybe, and it's not me.
                    TTSBF
                    RTCTTFMF PTOSITW
                    • z31Z
                      z31Z
                      z31
                      You going to put your car in the all Ford car show at the track?
                      • XJHEADX
                        XJHEADX
                        XJHEAD
                        I was planning on it. Even if not running but it is rollable, I will take it over there.
                        TTSBF
                        RTCTTFMF PTOSITW
                        • 63vette6
                          63vette6
                          63vette
                          Pretty common for Fords to be pushed to car shows. Bong!!!!!
                          • 63vette6
                            63vette6
                            63vette
                            I can weld aluminum between 3 and 5 beers. Any less or any more and I cant. :icon_scratch::icon_scratch::icon_scratch:
                            • GrrG
                              GrrG
                              Grr
                              im in the same boat, i shake too much to weld alum properly unless i have a couple beers first, lol
                              • XJHEADX
                                XJHEADX
                                XJHEAD
                                Before I put the intake on I figured it was a good idea to port match it. I took about an 1/8" off two sides of each port. Should have done that along time ago. Had to trim the gaskets too. Wrapped headers last night and tonight. Pulled turbos apart to check them out and cleaned them up.
                                TTSBF
                                RTCTTFMF PTOSITW
                                • C
                                  C
                                  Cobra Rob
                                  as a mustang lover this is very sick keep up the good work
                                  • z31Z
                                    z31Z
                                    z31
                                    That intake elbow going to clear the hood? :icon_scratch:
                                    • z31Z
                                      z31Z
                                      z31
                                      What kinda power will that motor make without the turbos?
                                      • XJHEADX
                                        XJHEADX
                                        XJHEAD
                                        Hope so, if not I'll get the chop saw out.
                                        When it was N/A it did 485 rwhp @ 6,000
                                        TTSBF
                                        RTCTTFMF PTOSITW
                                        • T
                                          T
                                          Trafik Jamz
                                          Looks exactly like it did last time I saw it Bill...
                                          of course that was 30mins before you posted these
                                          701.541.3484
