  4. belt squeal?
belt squeal?
24 Posts 12 Posters 1.4k Views
  • TsiTomT Offline
    TsiTomT Offline
    TsiTom
    My car has developed a slight belt squeal it seems...i was poking around and i tightened both the power steering and the alternator. Im about 95% positive its something with the power steering because when i crank the wheel back and forth (lock to lock) the squealing goes away. Im hoping its something as simple as a bad belt or something...but could it be worse? I looked under the wheel well at the crank pulley and you can kinda tell the source of the squealing is coming from there. Any thoughts? Im praying its not a bad bearing or something :eek:
    Tom Opgrand
    2011 Camry
    • My NOvaM Offline
      My NOvaM Offline
      My NOva
      try checking ur power steering fluid leval
      Hey Tina come get some hamm
      • TsiTomT Offline
        TsiTomT Offline
        TsiTom
        The fluid level is pretty adequate...could the wrong fluid cause a problem? I never put any in but is it possible?
        Tom Opgrand
        2011 Camry
        • My NOvaM Offline
          My NOvaM Offline
          My NOva
          what kind did u use?
          • TsiTomT Offline
            TsiTomT Offline
            TsiTom
            not a clue...only had the car for a week 😛
            Tom Opgrand
            2011 Camry
            • TsiTomT Offline
              TsiTomT Offline
              TsiTom
              i did buy a new belt though...if its nice again tomorrow ill change it and see what that does too..
              Tom Opgrand
              2011 Camry
                if your steering wheel moves easily its not the fluid..and probably not the belt..unless its just a little loose....not really sure.
                  well your in luck its supposed to be like 45! haha
                  • TsiTomT Offline
                    TsiTomT Offline
                    TsiTom
                    haha awesome...this wouldnt be a big deal but there is sort of a metal on metal grinding sound too...not really loud but you can catch it
                    Tom Opgrand
                    2011 Camry
                      isnt that kinda normal on a 1g?
                        cross your fingers, squeeze your nuts, and pray the cups on your rack arnt shot....
                          wow. nuts, cups, and rack all in the same post.. and it wasnt a drunk story.
                          anyway. back on topic...
                            What year is your car? 7 bolt engine? Do you by chance have Crank Walk? I hope not , but thats the worst that could happin... lol
                            DSM'rs lets all pray for him!!
                            Kevin
                            sls
                              exactly what i thought when i first read this...hope its not crankwalk for him...1 week in his possession....dont worry im praying for him
                                listen to what he's saying here.... if you turn the wheel from lock to lock it goes away... if it was something crank/thurst bearing related, that would have no effect on the noise.... Tom is the belt loose, or does it feel tight? Just replace that, and get it tightened tomorrow, and see where that puts you.
                                  it makes a grinding noise at idle and goes away when you turn the wheel?
                                  • 9 Offline
                                    9 Offline
                                    92TSIpos
                                    put some belt dressing on it once. that works for me.
                                      i just say if its the ps, just get ride of it!
                                      • TsiTomT Offline
                                        TsiTomT Offline
                                        TsiTom
                                        Well here is what i did this weekend to it....first of all i checked the actual fluid and its supposed to be dexron III auto tranny fluid....the fluid was brown, sooo that i changed that out...and i tightened the belt but its still squealing...next plan of action is to just spray some wd40 on the crank pulley and pray for the best.....if that doesnt work then i might start thinking bearing but im not going to get ahead of myself just yet...
                                        Tom Opgrand
                                        2011 Camry
                                        • O Offline
                                          O Offline
                                          out there
                                          hello? alternator belt? without hearing it in person, of course
