  2. Introductions
  3. Introductions
  4. hey i am new. whats up
142 Posts 33 Posters 14.3k Views
  • Bp-08B
    Bp-08B
    Bp-08
    D S ohM;276506 wrote:
    no way. 3 cams, 3 turbos. Gotta keep a 1:1 ratio on that shiz.
    maybe 8 turbos, one for every exhaust port.
    • funky_monkey58F
      funky_monkey58F
      funky_monkey58
      Hell man we are just going to replace the entire engine with a turbo!
      • JN210J
        JN210J
        JN210
        then run it on some jet fuel.
        *1989 Nissan 300ZX Z31 *
        DelSlow;262050 wrote:
        I like the new JN210
        • kylushK
          kylushK
          kylush
          with nitrous
          1998 Z28 Camaro
          • ParkerP
            ParkerP
            Parker
            no reply.. must have gone to jail?
            10 Jeep
            10 F450
            08 F250
            05 F350
            86 rx7
            70 F100
            63 Olds
            BlueSRT0483;244555 wrote:
            As proven by Parker... Not everything you read on the internet is true.
            Trafik Jamz;260984 wrote:
            You are right Parker.
            • C
              C
              Cobra Rob
              I work at walmart and we have these kind of theives in their all the time we do not have cameras in toys so they bring items to toys and open the packages and stealing anything from condoms to hand held vetc games for babies
              your going to get caught one of these days
              • T
                T
                Trafik Jamz
                Nice going...you just let the world know where the vulnerability is in your organization....
                701.541.3484
                • 2000V8Firebird2
                  2000V8Firebird2
                  2000V8Firebird
                  this is my car
                  aka best manual driver ever ;)
                  • T
                    T
                    Trafik Jamz
                    Ummm....nice car, but uhh...why in this thread?
                    701.541.3484
                    • JimJ
                      JimJ
                      LOL n00bs
                      • zbrownZ
                        zbrownZ
                        my oh my, noobs lately
                        rx7-8.89@157mph
                        12v dodge, twins
                        • T
                          T
                          Trafik Jamz
                          Haven't seen n00bs like this since...what...August of 2006?
                          701.541.3484
                          • C
                            C
                            Cobra Rob
                            I did not mean to give walmart secerts away but they loose tons of products from these fools
                            • SmitEvoS
                              SmitEvoS
                              Watch out, they might go bankrupt...
                              • C
                                C
                                Cobra Rob
                                yeah they told the employees fargo walmart made 20 million profit last year i think chould get a raise
                                • D S ohMD
                                  D S ohMD
                                  D S ohM
                                  Must be a legendary ride? :icon_scratch:
                                  I wanna go fast!
                                  • ParkerP
                                    ParkerP
                                    Parker
                                    gay...
                                    10 Jeep
                                    10 F450
                                    08 F250
                                    05 F350
                                    86 rx7
                                    70 F100
                                    63 Olds
                                    • 2000V8Firebird2
                                      2000V8Firebird2
                                      2000V8Firebird
                                      cuz i didn't know where else to put it and plus i saw the first page a noob put his car up so i thought i would join him
                                      • bubbaB
                                        bubbaB
                                        DaveH;276062 wrote:
                                        I dunno too much about Honda's, but I'd guess the clutch change would go something like this. Any honda guys correct me if I get off track:
                                        1. Jack the car up and put it on jackstands
                                        2. Unhook the lower ball joint/control arm/(whatever hondas have) enough to swing the front hubs out. Impact off the CV shaft nuts and then pull the shafts out of the hub.
                                        3. Use a small prybar to get the cv shafts out of the tranny. Unhook the shifter linkage from the trans, unhook the exhaust and any other honda doo dads you see that might keep the tranny from coming out.
                                        4. Support the engine with a jack/jackstand, and then unbolt the tranny from the chassis (I assume the trans has one of the motor motor mounts on it?). Then support the tranny with a jack, and unbolt it the trans from the engine. Use the jack to help separate the trans from the engine, then lower it and go set it somewhere out of the way.
                                        5. unbolt the pressure plate, and remove it along with the worn out clutch disk. Check the flywheel for wear/damage and go get it surfaced if it's beat up (Quality engine, M&J, etc).
                                        6. using clutch alignment tool, install the new clutch disk/pressure plate on the freshly surfaced flywheel. torque pressure plate bolts to spec.
                                        7. Install the trans back on the motor and re-hook up anything you too apart in 1-4. Take car off of jack stands.
                                        8. Start car up, rev to 8000 rpm and drop the clutch and do a smokey burnout. (new clutches like this).
                                        :icon_santa:
                                        Most of the time it's pull the engine & trans out, put the clutch in and then drop it back in... usually quicker outside the car then trying to put the trans in with the motor still in...
                                        • bubbaB
                                          bubbaB
                                          so... i'd say welcome... but ur a theif... u can leave now...
