  4. finally more turbo for the diesel
44 Posts 13 Posters 4.2k Views
  • 91nbtsi9 Offline
    91nbtsi9 Offline
    91nbtsi
    Zach, is your trans built?
    [email protected] -- DSM
    07 Mega Cab 5.9 CTD
    • zbrownZ Offline
      zbrownZ Offline
      my pickup had fueling mods before i got it.....so i don't know if he did something to the stock tranny or not...
      but somehow it shifts and holds every gear like a million bucks.... so either it was built somewhat awhile back or i am just really really lucky so far, haha
      It will go to Goerend for all the goodies when it does shit.... But yes i do have a billet 3 disk Goerend converter, that was a huge difference over the stock converter
      rx7-8.89@157mph
      12v dodge, twins
      • zbrownZ Offline
        zbrownZ Offline
        Anyway got this on tonight and it is absolutely sick in the difference, cant wipe my smile off yet
        spools very nice yet, and is a freight train up top now instead of falling off..... egts never go above 1300
        and the sound is ridiculous sick
        so happy!!
        rx7-8.89@157mph
        12v dodge, twins
          vid or it didnt happen!
          • beachbum_jonB Offline
            beachbum_jon
            nice, good job, what injectors and fueling mods do you have?
            -John Adams, 1735-1826-
            • zbrownZ Offline
              zbrownZ Offline
              DDP 140 sticks, #0 fuel plate, 4k governor springs
              edit, and timing is bumped to 16.5*
              rx7-8.89@157mph
              12v dodge, twins
                beachbum_jon
                ahh alright. have you heard of the new kit where you can make your stock p7100 into a 16mm pump by swaping out the delivery valves and the rack? and its suppose to only cost a few hundred. but im guessing it wouldnt be very street able, be like driving around with a sigma...
                  I just saw a BD Super B going on a Cummins today....
                    want a cookie?
                      King Ricer;298713 wrote:
                      want a cookie?
                      yup! come bring it to me!
                      • zbrownZ Offline
                        zbrownZ Offline
                        The "super B" is a 57mm comp, and a 65mm turbine
                        The "super B special" is a 64.5mm comp, and a 71mm turbine... which is what i have
                        was it on a 3rd gen truck?? cuz even just the super B would be a huge upgrade over the 9cm hotside on the stock turbo, that thing is big EGT maker
                        rx7-8.89@157mph
                        12v dodge, twins
                          for you
                            Just the smaller one. Went on an 01 24v. The compressor housing looks smaller than the hx35 that came off.
                            • BookemB Offline
                              BookemB Offline
                              Bookem
                              Hey Zac, does that have the wastegate on it or is that the difference with the 35w? We have one wearing out, and looking for a used replacement.
                              Legacy GT
                              Gmc Suburban
                              Hallorann: Fargostreet?
                              Hallorann: No, I ain't.
                              • zbrownZ Offline
                                zbrownZ Offline
                                are you asking on the original or new turbo?
                                but yes both the new and old are wastegated
                                old is only wastegates one volute... new does both and they are big
                                rx7-8.89@157mph
                                12v dodge, twins
                                  beachbum_jon
                                  zac, have you loaded your engine much yet? im curious how it will pull while towing
                                  • zbrownZ Offline
                                    zbrownZ Offline
                                    no, nothing really heavy yet
                                    but honestly I am amazed how it is working..... don't know why people say you dont want to pull with a 64?? unless it is that much different in a maunual truck?? I almost wish i would have went with a 66 as seeing how responsive the 64 is
                                    At unloaded cruising i now see slightly higher EGT's and lower boost pressures.....(should help some with mileage from easier engine breathing). but with a little bit of load it will quickly trasition into good boost with out any smoke or hesitation.... then the EGTs stay way way lower than they would have with the stocker under any load
                                    We will be hauling calves in a week or two so that will be 25k lbs.... see then what it does with a heavy load. Should get a vid showing all the guages when i am loaded like that accelerating and cruising loaded.
                                    As of now i love it... and really see no absolute need for twins... I know now that i could go to a 66 if i needed more and still spool it to my liking
                                    jacobs give your 2 cents, you rode in it and can attest to the spooling, EGT's, and power increase
                                    Its still a tossup as to whether the 4K governor springs, torque converter change, or turbo swap made the single most impressive change all by itslef
                                    rx7-8.89@157mph
                                    12v dodge, twins
                                      beachbum_jon
                                      64 sucks with a manual, even with a bigger pump and chip turned up all the way. it was annoying to drive, once it spooled it was decent, but the twins are soooo much better. we pulled a 25ft enclosed car trailer with a early 80's delta 88, fridge, washer & dryer, big tv, and lots and lots and lots of heavy boxes and tools and stuff from phoenix up to flagstaff (up a mountain) and with the monster pump, ddp 150's and the twins, it pulled amazing, and beleive me, we were doing 80 the whole way up and could still accelerate quickly
                                      • BookemB Offline
                                        BookemB Offline
                                        Bookem
                                        Old one, looking for one used and local. Wasn't sure if that works in place of the commercial 35w though.
                                        Legacy GT
                                        Gmc Suburban
                                        • DrifterExtremeD Offline
                                          DrifterExtreme
                                          I will kill you zac if you sell that thing.... :mad:
