  4. 240SX Problems
240SX Problems
69 Posts 13 Posters 3.0k Views
    i know a place in fargo that has the capabilites to flow test injectors
    • McAdamM Offline
      McAdamM Offline
      McAdam
      what type/style of AFC do you have? do you have it adjusted correctly? running too rich will foul plugs, but running too lean will cause pops, usually. also, is your TPS out of adjustment? I know on older nissans, you can adjust the tps within like a 15 degree range of motion.
      McAdam
      Nitrous is kind of like a hot chick with STD's.... You know you wanna hit it, but you're afraid of the consequences!
        if you have a good injector that you know is a 370 and a 550 take yours out and call midland diesel service they have injector cleaners and stuff, but they dont have a unit that calculates what they actually flow but they flow into a tube and you could see differances in amounts that came out. my dad works there talk to craig
          well...it could be my maf but supposedly the car wont run if the maf is not plugged in right? If it is wired wrong changes are its sending weird signals if anything to the ECU...wait now that i think of it he had it unplugged when i got there and it was running and i actually drove it unplugged and he told me that it was unplugged later...we had to actually set up the AFC when we got to the car since it was set up wrong the first time so I know FOR SURE this time it has the right In and Out numbers...and all fuel is stock except for a 255HP pump...I have a SAFCII...on the way home and up until the other day it had been completely zero'd out so it was basically outta the system...i just recently took 5% off of the fuel from like 3k or so all the way up...yeah i was told it looks rich(black smoke and now fouled plugs) but smells lean so wtf does that mean? I did actually adjust my TPS and got the right .45v and 4.05v out of it...
          The car came with bored out 550s in a box but im starting to wonder if he actually took em out or not...maybe i could compare the 2 and find out which ones are bigger etc...
          • PhatsP Offline
            PhatsP Offline
            Phats
            soooo, you drove it with the maf sensor unplugged???
            02 GSXR-1000
            97 540i
              yeah i did when it was in NY cause i guess it was unplugged...is that right that it doesnt run with it unplugged? i know my DSM would run without it...
              • PhatsP Offline
                PhatsP Offline
                Phats
                yeah, not right.......yet so odd, that i'm not completely surewhat it means.........
                02 GSXR-1000
                97 540i
                  who is the person that would be able to come down and help? I hear there might be some beer involved...
                  • PhatsP Offline
                    PhatsP Offline
                    Phats
                    lol, i will try to talk him into coming down, it may not be until this weekend.....
                    02 GSXR-1000
                    97 540i
                      bump...the car revs normally with the MAF unplugged...only supposed to rev to 2500...my IACV is completely unhooked so do i actually need it or not? Something with ECU or wiring...the harness was done by wiring specialties so it wasnt a homemade job...im thinkin it might be somethin with the AFC since im sure that was done himself...
                        i took the iacv thing off of my car and it runs fine after you let it idle for a while
                          do you have your Sr20 in yet? any chance i could borrow your ecu for like 5mins?
                            any available ecus or anything?
                              nope, no sr20. dont think im going to do that. talk to the gf guys on tintmasters
                                yeah i have been...i thought you already ordered your clip?
                                • stephen bradleyS Offline
                                  stephen bradley
                                  Tony sounds like your due for a little bit of good luck.
                                  • Unknown
                                    Yup...just looked at the maf tonight...thought it was wired wrong...now i think its right but hmm maybe its a bad maf?
                                      i sort off ordered a clip and then canceled before final payemnt. figured there was cheaper ways to make equal or more power.
                                        ya now we both have none running 240's. stupid wet corner and driving nice now my motor is in trash
                                          well mine runs and drives 🙂 what happened now?
