  4. Car sputtering under heavy load
34 Posts 11 Posters 4.1k Views
    should...you'll definately notice it
      seanjohn
      Alright, here's the question now:
      Like I said, I'm not too familiar with the ignition on these motors. The ecu is obd0 and the head is a b16. Now, when I bought the car I can remember the seller telling me that the dizzy on their was either obd1 or and ls dizzy. I can't remember for sure, but I know something was different about it. So my question is, are caps/rotors interchangable between all the b-series?
      Also, I've read up and found it could possibly be the ignitor....??? Sound possible?
        When a honda ignitor dies they usually leave the car stranded.
        OBD I distributor is unlikely as well, as you don't have an OBD 0 -> OBD 1 harness conversion installed. LS distributor would be noticeable because one of the ears of the dizzy would have to be cut off in order to bolt it to the b16 head.
          seanjohn
          Hmm...I am going to inspect the dizzy tomorrow. But I am almost positive that he said he had to trim something in order to get the dizzy to work with the head. In the case that it is an LS dizzy, should I buy a cap and rotor for the b18a or for the b16? Come to think of it, it would be impossible to buy a cap/rotor for a obd0 b16 specific distributor, so I'd have to get the LS pieces, right (assuming they are different).
            If you cut a leg off of the distributor it is an LS and you will watn a B18a cap/rotor. If not, some USDM parts will work on the OBD 0 b16 distributors. I think obd II GSR might be the correct fit, but do not quote me on that, as it has been a few years since I've had to round up OBD 0 dizzy parts.
              seanjohn
              Good info...I'm kinda hoping it's an ls unit, just because it should be easier to get parts from.
                seanjohn
                Someone recently mentioned that my cam timing might be off, unfortunately I have never adjusted it before, and its possible that after replacing the timing belt and crank pulley that it has moved, so I need to know how to check it:
                From what I understand, I turn the motor until the markings on the cam gears point to eachother, then I check the marking on the crank pulley and see that it lines up with the notch on the lower timing belt cover...does this sound correct?
                  Correct. Line the cam gears up with each other, and then check the timing belt down by the crank pulley. If the markings line up down there, then you should be fine.
                  I would say with the way your car was running this weekend that the timing belt isn't off. Have you rounded up some distributor parts yet?
                    seanjohn
                    Yep, going to get the cap and coil from napa today...going to replace it this evening. I remember doing the timing on a SOHC motor back in the day, and I kept having problems with the belt skipping a tooth. The motor would hardly run afterwards, which leads me to believe that my timing is probably fine.
                    edit
                    Cap and Coil from napa totaled like $120....typically no biggy, but I can opt for the msd modified dizzy cap and external coil for like $80. I am going to be going with the digital 6 or 7 in the near future, so I think I am going to order the MSD stuff now and use it with an inline ballast resistor until I get my digital unit.
                      You shouldn't need the coil. I'd just opt for the cap/rotor.
                      I might have a GSR cap/coil in my storage shed somewhere as well.
                        seanjohn
                        I was under the assumption that the obd1-2 caps didn't fit on the obd0 dizzy's....am i wrong?
                          seanjohn... I'm buying an ls swap, and thinking about going ls/vtec, had some questions for you on your build. you on msn or aol? pm me your username if you are.
                            seanjohn
                            Sure thing, msn screename is [email protected]...I'll answer everything I can.
                              I don't remember if the caps are the same, however the coil would probably work. I will try and get over there in the next couple days to find it.
