  4. my new car
my new car
37 Posts 13 Posters 1.6k Views
  • C Offline
    C Offline
    CivicEX7777777
    That and the fact that it needs a new wiper motor are the only reasons I didnt buy it, I got a 92 Nissan Sentra XE instead
    2007 Pontiac G5
    2007 Yamaha C3
    2002 Oldsmobile Alero
    1994 Nissan Sentra
    • krzydrftr93K Offline
      krzydrftr93
      he is just like shane.. spend money on cars not worth put money into but hey whatever they are enjoying it
      Matt
      92 Civic HB
      JDM d15b w/14b@8psi
      • assasainA Offline
        assasainA Offline
        assasain
        lol yep.... i dont care if its worth it i just wanna have fun :):):)
          krzydrftr93
          Thats what its about in my mind. Get some decent hp out of that thing and it could be a lot of fun
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            shane it never needed a new wiper motor, just for it to be put back in...
            • C Offline
              C Offline
              CivicEX7777777
              Oh I thought you said it needed new one, thats part of the reason why i couldnt get it
              2007 Pontiac G5
              2007 Yamaha C3
              1994 Nissan Sentra
              • 91nbtsi9 Offline
                91nbtsi9 Offline
                91nbtsi
                Check out www.club4ag.com. There are a few engines that bolt right in. Sucks that you have a non-lsd rear and other things, but oh well. I would probably just beat the shit out of it as it is, more fun that way.
                [email protected] -- DSM
                07 Mega Cab 5.9 CTD
                • assasainA Offline
                  assasainA Offline
                  assasain
                  i already joined them i just havn't posted yet.... thanks 🙂
                  ya i actually got it so the trunk latched and stays but havn't got it to be able to pop open, but i did install the windshield wiper motor and wipers and now those work too....... next thing to work on is the dash lights then the clutch and onward from there......
                    Here I looked up the diffrence between the Gt-S and the Sr-5. It's going to take a ton of work/money, but good luck.
                    4A-GE engine (and all brackets to support peripheral equipment)
                    2.
                    Most peripherals such as A/C, P/S pumps and compressors
                    3.
                    Complete intake and exhaust runners and headers
                    4.
                    Fuel pump and lines
                    5.
                    Gasoline tank, evaporation and related items
                    6.
                    Clutch fork and fluid line locations and bell housing (GTS and SR5 has opposite side clutch fork and slave due to the differences in the exhaust runner location and is extremely important not to run fluid lines next to exhaust systems)
                    7.
                    Transmission is the same unit as the GTS (T50C), however the speedometer gear is different, and must be replaced to read correct speed on the cluster. (due to different final drive ratio)
                    8.
                    EFI computer triggers and sensors
                    AFM or MAP
                    Air Temp Sensor (MAP only)
                    distributor assembly (MAP and AFM based are different)
                    Igniter and Coils (different for AFM and MAP based)
                    EFI Computer (MAP or AFM specific)
                    House Harness and Engine Harness and related junction boxes
                    All relays and VSV triggers
                    peripheral VSV triggers
                    Battery terminals and fusible link terminals and fuse box
                    some of these can be ignored for carburetor use such as Weber Side-draft carburetors
                    9.
                    Ignition system
                    10.
                    Dash Cluster missing check engine (W) lamp
                    11.
                    Labor and Installation Professional who can proceed properly so as not to create more problems (cheap or un-skilled installer would render the 4A-GE less powerful and unbelievably unreliable.
                    12.
                    Oil cooler, block and lines
                    13.
                    Clutch and flywheel
                    Now as for other items that are mechanically different from the GT-S (4A-GE equipped models):
                    Differential carrier
                    2.
                    Differential gear, axles, hub assembly (need 4A-GE unit to utilize commonly available LSD)
                    3.
                    Rear disk brakes vs. drum and related lines and cables (except Japanese GT)
                    4.
                    Steering rack, knuckles, tie rods
                    5.
                    Propeller shaft
                    6.
                    Clutch fork, assembly, cables, lines, bell housing (as mentioned above)
                    7.
                    Front and rear suspension are different from factory in spec but can be interchanged (Not significant as most owners replace them with aftermarket systems anyway)
                    • AcesHighA Offline
                      AcesHighA Offline
                      AcesHigh
                      2.
                      3.
                      4.
                      Fuel pump and lines
                      5.
                      6.
                      7.
                      8.
                      AFM or MAP
                      9.
                      Ignition system
                      10.
                      11.
                      12.
                      13.
                      Clutch and flywheel
                      2.
                      3.
                      4.
                      5.
                      Propeller shaft
                      6.
                      7.
                      owned 🙂 have fun
                      2005 Mercedes-Benz C240 4Matic
                      1993 Mazda Rx-7 Twin Turbo (sold)
                        we already knew it was very different...
                          krzydrftr93
                          Well start saving now and maybe by this time next year you will be ready to start the build.
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                          • 3_Series3 Offline
                            3_Series3 Offline
                            3_Series
                            2.
                            3.
                            4.
                            Fuel pump and lines
                            5.
                            6.
                            7.
                            8.
                            AFM or MAP
                            9.
                            Ignition system
                            10.
                            11.
                            12.
                            13.
                            Clutch and flywheel
                            2.
                            3.
                            4.
                            5.
                            Propeller shaft
                            6.
                            7.
                            Did he ever say he was gonna do a GT-S conversion? He only mentioned a motor swap...
                            2002 Subaru Legacy
                            1993 BMW 325i (sold)
                            • sitn2loS Offline
                              sitn2loS Offline
                              sitn2lo
                              waste of money... just use it as a winter beater dont swap it (but also if u think u can do it then do it.)and dont put the gay ass apc shit on it....like someone on here did...
                              Yukon Denali on 22's
                                krzydrftr93
                                I dont have anything APC on my car. I have AEM intake Cf spoon mirrors from jdmcarboy, CF spoon style spoiler from tintmasters type r titanium shift knob and type r red stiched shift boot from tintmasters and tint from them. Saving for password:jdm sturt bars or jic magic bars. SO I DONT HAVE GAY SHIT ON MY CAR ALRIGHT.
                                Matt
                                92 Civic HB
                                JDM d15b w/14b@8psi
                                  Who are you talking to? Everybody already left this thread already screaming, I just dropped by to turn out the light...
