  2. Introductions
  3. Introductions
  4. My car and I
My car and I
27 Posts 18 Posters 1.7k Views
  • Meat WagonM Offline
    Meat WagonM Offline
    Meat Wagon
    ticklemedaly wrote:
    wouldn't you pull more power with regular 93 or higher unleaded octane? or just adding a little racing fuel to the tank too? I believe E85 has lower power figures and worse gas mileage.
    Ry
    Sorry, but you're wrong. If you want to compare octane ratings, e85 is rated at 105 octane. I'm paying $2.49 a gallon right now for e85. I beleive c16 is around $9-10 a gallon. You do need to run more ethanol to equal the same amount of gas. Anywhere from 20-50% more fuel. I get about 22mpg on e85. The best part of e85 is that it burns cool. Last week on an 80 degree day my intake temp was 94 degrees. After some spirited driving the intake manifold is room temperature to the touch.
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      91nbtsi
      What does your fuel burning cool have to do with your intake temps? Aside from the small amount of heat transfer that will occur from your head to your intake during operation and any reversion... Intake temps are dependent on the efficiency of your turbo, IC, and the temp of the intake into the turbo.
      Anyways though, E85 is higher octane and does have good potential. But, like you say, you need more of it; about 1.5times as much IIRC.
      Now, E85 does burn cooler, but your intake temps aren't a direct result of this unless you are maybe sucking in exhaust gasses?? Your combustion and exhaust temps should be lower, which allows wilder tuning:icon_thumleft:
      I should get some bigger injectors and run the Yota on E85...:icon_scratch:
      [email protected] -- DSM
      07 Mega Cab 5.9 CTD
      • 3_Series3 Offline
        3_Series3 Offline
        3_Series
        E85 has about a 25-30% disparity in mileage compared to gasoline. Car and Driver tested a flex-fuel Tahoe with both fuels and consistently achieved higher mileage with 87 oct (E85 reduced driving range by about 100 miles). Albeit E85 did have slightly better performance, but the figures are insignificant at best.
        2002 Subaru Legacy
        1993 BMW 325i (sold)
          Meat WagonM Offline
          Meat Wagon
          It works on the same principal as Methanol but just not as effective. Ethanol vaporizes with the incoming air to reduce intake temps. The reason need to run 50% more fuel is to have some ethanol injected into the combustion chamber after the vaporization has occured. Thats why on a car running methanol you don't need an intercooler or sometimes even a radiator. The cooler the air coming in, the more power you can make.
          • 1990TSI1 Offline
            1990TSI1 Offline
            1990TSI
            welcome, and nice car!
            97 ek hatch gsr swap soon for boost, 97 ek coupe sold!, 97 ek coupe winter beater/ rally racer, 94 eg coupe, 94 eg coupe, 94 civic coupe RHD project finished!, 94 eg sedan parts car, 94 dc teg parts car, 92 gsr parts car, 92 eg hatch sold!, 91 da parts car, 91 integra sold!, 89 civic hatch sold!, 90 awd talon-sold, 91 fwd tsi parts car-crushed!! hahaha, 91 na eclipse-sold, 93 na eclipse-sold, 94 na dsm parts car
              Props on using e85...i brought it up a couple times here and got shot down each time...love seeing someone use it!
                PUREVIL-K20
                ha ha Cory its looks like a monster as allways...
                welcome to the forum.
                2002 Acura nbp Rsx Type S
                AEM SRI FS!
                Tsudo Fireball Catback - on this week
                Strup header - on this week
                K-pro 8-12-06!!!
                JDM blackhousing headlights
                PIAA Xtreme white bulbs
                Greddy Front lip
                Type R rear lip
                CW Sides, install ASAP
                BC N+ sus
                PIAA bulbs
                Tinted windows
                Painted Calipers
                H emblems front and rear
                C/F manifold cover
                ARC intake
                Skunk 2 shift knob
                17x7 Nippon Gunmetal wheels 17lbs ea
                Toyo 555 225/40/17 tires
                19x8 n 19x9 inch ESTATUS ON TOYO 555 - For Sale
