Ecu
Anyone have a JDM P08 ECU???
Well from my research(yes I did some research) Vtec kicks in later on the p28 i got from phearable and so I will loose power. So therefore I want a P08
wannabe wrote:
for the millionth time, Honda sets vtec at a certain point for a certain reason, messing with your vtec point with stock cams/stock motor is an idiot move.
Joel the P08 goes with the damn motor So therefore I wouldnt be fucking with the vtec point if i used a virgin P08 now would i. -
wannabe wrote:
for the millionth time, Honda sets vtec at a certain point for a certain reason, messing with your vtec point with stock cams/stock motor is an idiot move.actually, a bit lower vtec can actually create a smoother dyno curve...learned that from somebody on here that knows a bit more about hondas than me and you joel...combined
ok joel calm down..... just do as bumpinjcc said easiest plan...
