  4. launching
launching
31 Posts 14 Posters 1.1k Views
    torbs wrote:
    So you are telling me that a mustang or slomaro with 400ish whp can run low 11's (using kevin's hatch as an example)...
    ok
    and as far as launching goes...rev limiter...drop 😉
    actually, I launch at around 4-5k...just depends on how much i wanna spin the tires (my sweet ass steelies y0)
    not sticking up for capitalj...but yes..if a mustang weighed the same as a civic did and it had 400hp...it would run low 11s
      my point is that a mustang with 400whp cant due to it's weight...my point was just that a civic with 400whp is faster than a mustang with 400hp...if you go power to weight ration and make them the same, then that's another story
        This is such a stupid argument. Weight is no the only factor. Traction, gearing, driver and suspension setup all play into it. There are mustangs with 400hp running low 11s.
          bc you've never said anything stupid...EVER...:p
            Nevar!
            The whole argument is stupid though. Like I said, there are a ton of factors plaing into it that are not even mentioned.
            • capitljC Offline
              capitljC Offline
              capitlj
              Indeed.
              > Mitch Hedberg wrote:
              2004 Impala LS 3.8
                Nick proved you an run 11's with 260hp in a civic. Lets see a mustang run a 13 with 260hp
                  im sure its possible. with right gearing, and setup ect.
                  • capitljC Offline
                    capitljC Offline
                    capitlj
                    Without a doubt. There are fox cougars and t-birds running 12s with only 325 hp and they are heavier than the stangs.
                    2004 Impala LS 3.8
                    • ChristianC Offline
                      ChristianC Offline
                      Christian
                      My Capri ran a 12.35 on motor with 311 hp to the wheels and a 12.80 on motor when it only had 245hp to the wheels. You have to remember on Mustangs you can change the gears very easy and they respond to that well.
                      Playtime Performance
                      93 Mustang 6.0l ... 9.99 @ 136
                      06 F-150 Lariat
                        Alright, I'll show you my slip next spring when I get some decent tires.
