DSM problem. :mad:
She is running great now but th oil light comes on every time I stop. I read on dsmtuenrs.com that this is OK but just wanted to double check with you guys.
At the minimum it is usually at if I sit for a long while once it is warm.
Can I come in and have it checked?
There's not really much to check. If you have low oil pressure then there's nothing short of replacing or rebuilding an engine that'll give you oil pressure. I'd just drive it for now and keep a good eye on it. I thought it might just be a bad sensor but if your guage reads low also, than it's a good indication that it's low. Save your pennies for an engine from SLS. They have done countless Jap-spec engine swaps and are reasonable about price.
