  4. really tight bolt removal
17 Posts 8 Posters 939 Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    I am trying to remove the sprockets on my bike. I dont know what the last person did, but they are way to tight to remove by hand. I actually ended up stripping my socket. Any suggestions on how to remove a bolt that is this tight?
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      Vise grips.
      • M Offline
        M Offline
        moparguy
        soak it in a quality penetrating fluid like JB-80 or PB Blaster. then wrench on it, sometimes use a box end wrench and a cheater on the end of it to get really stubborn bolts out.
        next step is heat. heat it up then try wrenching on it. but dont forgot ya heated it up. it hurts. haha
          91nbtsi wrote:
          Vise grips.
          Bad idea. If the bolt is not stripped you will strip it by using vice grips
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            Not if you aren't a pussy.:icon_thumright:
            I am JK btw, use the vice grips as a last resort...
              lollerskates
              I have found that just heating the bolt works 95% of the time
              • F Offline
                F Offline
                Fitzy
                Impact gun
                2002 Honda S2000
                2006 Dodge Ram CTD
                • jct_4628J Offline
                  jct_4628J Offline
                  jct_4628
                  what do you heat the bolt with?
                  Jason
                  -06 WRX
                  -95 CBR 600F3
                  701-541-2568
                    use a blow torch..........:p
                    • jct_4628J Offline
                      jct_4628J Offline
                      jct_4628
                      even if I had one, I dont think I would use it.
                      Jason
                      -06 WRX
                      -95 CBR 600F3
                      701-541-2568
                        just giving you some crap.......would a heat gun work?
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          Um, you heat the bolt with a torch...
                          • jct_4628J Offline
                            jct_4628J Offline
                            jct_4628
                            I have a soldering iron, could I just set it on the bolt and let it warm up?
                            Also, do you think an impact driver might work?
                            Jason
                            -06 WRX
                            -95 CBR 600F3
                            701-541-2568
                            • 91nbtsi9 Offline
                              91nbtsi9 Offline
                              No, soldering iron probably won't work. Use an impact with a 6 pt socket.
                                ALWAYS use a 6pt socket for tight bolts...
                                  No. A soldering iron is for wires, not bolts.
                                  Just go to the store and buy a propane torch. They are pretty cheap. Heating the bolt up along with a large breaker bar will remove it pretty easily.
                                  • CheapSRTC Offline
                                    CheapSRTC Offline
                                    CheapSRT
                                    :drunken_smilie: Get a bigger hammer!!!:drunken_smilie:
                                    If your ice skateing down the street and a wheel falls off your canoe, how many pancakes will it take to top a dog house?
                                    None, because ice cream has no bones.
                                    turbo IQ test
                                    http://www.honeywell.com/sites/ts/tt/turbofactsbenifits_IQtest.htm
