  4. really tight bolt removal
17 Posts 8 Posters 1.1k Views
  • M
    M
    moparguy
    soak it in a quality penetrating fluid like JB-80 or PB Blaster. then wrench on it, sometimes use a box end wrench and a cheater on the end of it to get really stubborn bolts out.
    next step is heat. heat it up then try wrenching on it. but dont forgot ya heated it up. it hurts. haha
    • MisterCMKM
      MisterCMKM
      91nbtsi wrote:
      Vise grips.
      Bad idea. If the bolt is not stripped you will strip it by using vice grips
      thrash;315544 wrote:
      Ford is back :)
      • 91nbtsi9
        91nbtsi9
        Not if you aren't a pussy.:icon_thumright:
        I am JK btw, use the vice grips as a last resort...
        • MisterCMKM
          MisterCMKM
          lollerskates
          I have found that just heating the bolt works 95% of the time
          Ford is back :)
          • F
            F
            Fitzy
            Impact gun
            2002 Honda S2000
            2006 Dodge Ram CTD
            • jct_4628J
              jct_4628J
              jct_4628
              what do you heat the bolt with?
              Jason
              -06 WRX
              -95 CBR 600F3
              701-541-2568
              • SmitEvoS
                SmitEvoS
                use a blow torch..........:p
                • jct_4628J
                  jct_4628J
                  jct_4628
                  even if I had one, I dont think I would use it.
                  Jason
                  -06 WRX
                  -95 CBR 600F3
                  701-541-2568
                  • SmitEvoS
                    SmitEvoS
                    just giving you some crap.......would a heat gun work?
                    • 91nbtsi9
                      91nbtsi9
                      Um, you heat the bolt with a torch...
                      • jct_4628J
                        jct_4628J
                        jct_4628
                        I have a soldering iron, could I just set it on the bolt and let it warm up?
                        Also, do you think an impact driver might work?
                        Jason
                        -06 WRX
                        -95 CBR 600F3
                        701-541-2568
                        • 91nbtsi9
                          91nbtsi9
                          No, soldering iron probably won't work. Use an impact with a 6 pt socket.
                          • PSiedTSiP
                            PSiedTSiP
                            ALWAYS use a 6pt socket for tight bolts...
                            spanish-rice;237125 wrote:
                            • MisterCMKM
                              MisterCMKM
                              No. A soldering iron is for wires, not bolts.
                              Just go to the store and buy a propane torch. They are pretty cheap. Heating the bolt up along with a large breaker bar will remove it pretty easily.
                              Ford is back :)
                              • CheapSRTC
                                CheapSRTC
                                CheapSRT
                                :drunken_smilie: Get a bigger hammer!!!:drunken_smilie:
                                If your ice skateing down the street and a wheel falls off your canoe, how many pancakes will it take to top a dog house?
                                None, because ice cream has no bones.
                                turbo IQ test
                                http://www.honeywell.com/sites/ts/tt/turbofactsbenifits_IQtest.htm
