  4. Dyno Queen
Dyno Queen
54 Posts 19 Posters 3.0k Views
  • Turbo5OhT Offline
    Turbo5OhT Offline
    Turbo5Oh
    what happened to the old set up? is that a crate engine or built? whats the specs? why twins?
    • XJHEADX Offline
      XJHEADX Offline
      Just wanted something different.. Took old set-up and dropped compression down to 9.0 Found a Twin set-up that was suppose to fit😕 :rolleyes: 😕
        twin whats? look like turbonetics housings, just cuz they're shiny, but i"m probably wrong.
        • Turbo5OhT Offline
          Turbo5OhT Offline
          Turbo5Oh
          yeah that tends to happen with the kits mine was suppose to be a bolt on single, ended up being a bolt and bend and bang and cut and weld on
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            Looking good! Will be fun to see it run.
            • dubbsyD Offline
              dubbsyD Offline
              Fargo wrote:
              More like, that poor checkbook
              your checkbook doesn't have to put up with all that horsepower though..
              going to an 8 point cage now then?
              (got any of the old parts laying around? been lookin for a cobra myself lately... may need some 'accessories' down the road.)
              • XJHEADX Offline
                XJHEADX Offline
                No need to change anything there. I am good to 10.00
                • dubbsyD Offline
                  dubbsyD Offline
                  for the sake of the car maybe?
                  that 6pt is good for 10.00? didn't figure it would be in a vert.
                  • XJHEADX Offline
                    XJHEADX Offline
                    I/C almost all done, need to hack into one bumper support for piping to throttle Body
                    Modified the front bumper to allow more air into I/C
                    • XJHEADX Offline
                      XJHEADX Offline
                      Finally got all the cold piping to fit, missing a couple clamps..
                      Have everything mocked up.
                      Radiator shroud doesn't fit anymore.
                      Off to SLS for a "little" welding :icon_colors:
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        Looking good man! When do you expect to be ready to run? Pretty exciting.
                        • camzaro28C Offline
                          camzaro28C Offline
                          camzaro28
                          dart block, single turbo, reminds me of wolverine down in FL. his fastest pass is 10.0@144
                          i hope to see u near or quicker then them numbers
                          jig 4 prez
                            that is going to be sweet. how much hp do expect with this setup
                            • XJHEADX Offline
                              XJHEADX Offline
                              I'll be back in town in two weeks, will pick it up from Nick then. As for when ready, hopefully I'll actually have some time to work on it in those two weeks I am in town only have had a few days this last week to work on it.
                              Need to pull motor one more time, I have only test fitted everything so far.
                              Shooting for about 1,000@20 psi E-85 if the turbos keep up..
                                on E-85 gas, thats interesting,
                                or did i miss understand you
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  you completely understood, should add 50++ hp probally closer to 100
                                    ^thats awsome, what are you going to use for tuning for it? especailly the e-85, have seprate maps for each fuel?
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      I am running Accel Gen. 7 DFI. I can upload as many tunes as I want...
                                      • StangerBanger96S Offline
                                        StangerBanger96
                                        you definitely have to update this thread when it's done getting tuned. I forget to go to TCStangs enough so if you update this one i'll see it actually!
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          Started it up friday night, got just a base tune on it for it to run on its own. Took it for a short test drive sat. Dynotune is picking it up this week, should be ready when I get back in two weeks.. In Arizona again, last time for a couple of months........
                                          BTW Nick, twins do not quiet down a V-8 at all:eek: :eek:
