  4. Problem with dsm.....lol
36 Posts 11 Posters 1.6k Views
  • DrifterExtremeD
    DrifterExtremeD
    shut up will....god damn fargostreet nazi...lol
    anyway does anyone have any real answers?
    • T
      T
      tranceman
      Do a boost leak test..You will probably find the source of your fuel cut. And get the Boost Gauge hooked up, that will also help you to see if your turbo is boosting properly/ also if your wastegate is working.
      1996 Mitsubishi Eclipse Spyder GS-T
      1992 Eagle Talon Tsi AWD
      • DrifterExtremeD
        DrifterExtremeD
        ok i had a coupler off before and it fuel cut and i fixed that then the same so i will check again for leakes going to hook up the boost gauge now..
        • DelSlowD
          DelSlowD
          Dang right im the fargostreet nazi. I wont stop till there is total obedience!:icon_farao:
          • DrifterExtremeD
            DrifterExtremeD
            haha....nice
            • K
              K
              do u need a boost gauge? i have one right next to me
              • DrifterExtremeD
                DrifterExtremeD
                So now i am feeling it is the wastegate because i feel a big fuel cut at around 25 psi on the autometer guage.... so how bad is this i have hit fuel cut 4 times and now i need wastegate. also i had to derectly connected to the wastegate from the j pipe....
                • PSiedTSiP
                  PSiedTSiP
                  wait 25psi? how modded is this car...?
                  spanish-rice;237125 wrote:
                  • DelSlowD
                    DelSlowD
                    Umm...none lol
                    • DrifterExtremeD
                      DrifterExtremeD
                      stock with a 3" exhaust
                      and i guess a bad wastegate
                      • PSiedTSiP
                        PSiedTSiP
                        yeah 25psi on stock fuel=BAD idea...
                        • DrifterExtremeD
                          DrifterExtremeD
                          thats why i need a wastegate
                            wastegate won't get you more fuel. Any idea what kind of AFR numbers you are running? Besides, 25psi on a stock turbo probably is a stupid idea, at some point all turbos run out of efficiency and just become huge heat pumps (this isn't a good thing) I dunno what the magic number is for DSM's, but I'm guessing 25psi is across that line.
                            For more fuel look to a walbro Fuel Pump and some aftermarket injectors...and an SAFC or some other sort of fuel computer along with a wideband O2 to properly tune this thing.
                            • JimJ
                              JimJ
                              ... This is why DSM's have a rep of being unreliable 🙂
                              Well they are but still, 25 psi on stock fuel... Try that on any other car...
                              • PSiedTSiP
                                PSiedTSiP
                                I'm guessing he just wants it to be stock...the wastegate obviously isnt opening at all...or if any just barely
                                • DrifterExtremeD
                                  DrifterExtremeD
                                  I just found a wastegate and no i don't want to boost 25 i need it stock for now so i will replae the wastegate and see if it fixes my problem.
                                  • SmitEvoS
                                    SmitEvoS
                                    Silly noobs........
                                    • DrifterExtremeD
                                      DrifterExtremeD
                                      I hope that wasn't focused towards me because i don't by any means wish to boost some stupid amount... just run it stock for awile
                                      • DelSlowD
                                        DelSlowD
                                        Matt= n00b :icon_compress:
                                        • darkelvisD
                                          darkelvisD
                                          darkelvis
                                          Ok, for those who aren't catching the e-sarcasm I will clear this up a little. Matt was getting horrible fuel cut in the DSM. The oh so reliable DSM boost gauge was telling him that he was getting fuel cut at only 7 psi so, we swapped in an aftermarket boost gauge and first gear spiked to 20 psi then held steady at 18 then in second gear the boost gauge ran all the way to 25 psi which is where he started getting fuel cut. According to the OEM gauge he was at 7 psi when this happened. And now we have the answer of bad wastegate. He is getting a new one to run the factory boost level (whatever the hell it is...I've heard 6 9 and 12) which is what he wants.
                                          The whole thread is filled with sarcasm and it appears that not too many people are catching it. 🙂
