  4. Borg Warner S200 Honda D Series Setup
33 Posts 19 Posters 2.1k Views
    a hotter spark wouldnt hurt...
    • krzydrftr93K Offline
      krzydrftr93
      That is pretty sick. I wish i had that motor in my car.
      Post some video up from the track once it gets out there
      Matt
      92 Civic HB
      JDM d15b w/14b@8psi
        whats the highest d series HP record? anyone ever hit 500?
          krzydrftr93
          theres a guy on honda tech with 502whp D-series
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            link or pix?
              krzydrftr93
              cant find pics for that one...go to turbod16 There are some 450plus ones there.
              ANd the guy on HT with the 500whp d is member TURBODCX. Sold the car for around 11,500
              Matt
              92 Civic HB
              JDM d15b w/14b@8psi
              • darkelvisD Offline
                darkelvisD Offline
                darkelvis
                Ignition boxes don't produce a "hotter spark." And yes, a hotter spark WOULD hurt (which is why you want to run colder plugs).
                  correct me if i am wrong.
                  an upgraded ignition would help buy prevent spark blow out allowing you to run more gap on your plugs,
                  edit: im dumb should have read it twice
                  • XJHEADX Offline
                    XJHEADX Offline
                    an upgraded ignition would help buy prevent spark blow out allowing you to run less gap on your plugs,
                    OK, you're wrong
                    • bader3245B Offline
                      bader3245B Offline
                      bader3245
                      You have it exactly backwards.
                      2008 Ford F-150 FX4
                      2006 Honda CRF250R
                      2006 Honda CBR1000RR
                        whoops i just reread that, run more plug gap whops, my bad
