  4. Borg Warner S200 Honda D Series Setup
33 Posts 19 Posters 2.1k Views
  • XJHEADX Offline
    XJHEADX Offline
    Fargo wrote:
    See ya friday right?????:icon_bounce:
    :mad: :mad: :mad:
      Got on the dyno yesterday w/ some decent results but we have pretty much found the limits of the stock cam, intake manifold, etc. Car was on a dyno dynamics dyno and put down 365 whp. They said their down has a correction factor of ~11% to a dynojet, @ that rate dynojet numbers should be around 405whp. We tried boost levels anywhere from 18-21 psi but anything over 18 psi provided minimal gains. Tried all the way 23-24 psi as well but the system was maxed and just ineffiecient and made no extra power over the lower boost levels. Next is to build a sheetmetal intake, install cam, and possible some mild head work and look for 450+whp.
          holy cow that awsome, time for some more parts and see what this beast can do
            The Honda says feed me more parts!
              ignition box possibly?
                It's not an ignition issue. Honda has a rather good stock ignition system.
                  a hotter spark wouldnt hurt...
                  • krzydrftr93K Offline
                    krzydrftr93
                    That is pretty sick. I wish i had that motor in my car.
                    Post some video up from the track once it gets out there
                    Matt
                    92 Civic HB
                    JDM d15b w/14b@8psi
                      whats the highest d series HP record? anyone ever hit 500?
                        krzydrftr93
                        theres a guy on honda tech with 502whp D-series
                        Matt
                        92 Civic HB
                        JDM d15b w/14b@8psi
                          link or pix?
                            krzydrftr93
                            cant find pics for that one...go to turbod16 There are some 450plus ones there.
                            ANd the guy on HT with the 500whp d is member TURBODCX. Sold the car for around 11,500
                            Matt
                            92 Civic HB
                            JDM d15b w/14b@8psi
                            • darkelvisD Offline
                              darkelvisD Offline
                              darkelvis
                              Ignition boxes don't produce a "hotter spark." And yes, a hotter spark WOULD hurt (which is why you want to run colder plugs).
                                correct me if i am wrong.
                                an upgraded ignition would help buy prevent spark blow out allowing you to run more gap on your plugs,
                                edit: im dumb should have read it twice
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  an upgraded ignition would help buy prevent spark blow out allowing you to run less gap on your plugs,
                                  OK, you're wrong
                                  • bader3245B Offline
                                    bader3245B Offline
                                    bader3245
                                    You have it exactly backwards.
                                    2008 Ford F-150 FX4
                                    2006 Honda CRF250R
                                    2006 Honda CBR1000RR
                                      whoops i just reread that, run more plug gap whops, my bad
