  4. Borg Warner S200 Honda D Series Setup
33 Posts 19 Posters 1.9k Views
  • LT1L Offline
    LT1L Offline
    LT1
    lookin good
      DaveH wrote:
      Looks like you are enjoying pie cutting.
      :icon_thumright:
      Not really, but im gonna be using a few of these setups as demo display items......
        Fargo wrote:
        See ya friday right?????:icon_bounce:
        Hopefully.......... Still fighting a losing battle, haha.
        • XJHEADX Offline
          XJHEADX Offline
          :mad: :mad: :mad:
            Got on the dyno yesterday w/ some decent results but we have pretty much found the limits of the stock cam, intake manifold, etc. Car was on a dyno dynamics dyno and put down 365 whp. They said their down has a correction factor of ~11% to a dynojet, @ that rate dynojet numbers should be around 405whp. We tried boost levels anywhere from 18-21 psi but anything over 18 psi provided minimal gains. Tried all the way 23-24 psi as well but the system was maxed and just ineffiecient and made no extra power over the lower boost levels. Next is to build a sheetmetal intake, install cam, and possible some mild head work and look for 450+whp.
                holy cow that awsome, time for some more parts and see what this beast can do
                  The Honda says feed me more parts!
                    ignition box possibly?
                      It's not an ignition issue. Honda has a rather good stock ignition system.
                        a hotter spark wouldnt hurt...
                        • krzydrftr93K Offline
                          krzydrftr93
                          That is pretty sick. I wish i had that motor in my car.
                          Post some video up from the track once it gets out there
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                            whats the highest d series HP record? anyone ever hit 500?
                              krzydrftr93
                              theres a guy on honda tech with 502whp D-series
                              Matt
                              92 Civic HB
                              JDM d15b w/14b@8psi
                                link or pix?
                                  krzydrftr93
                                  cant find pics for that one...go to turbod16 There are some 450plus ones there.
                                  ANd the guy on HT with the 500whp d is member TURBODCX. Sold the car for around 11,500
                                  Matt
                                  92 Civic HB
                                  JDM d15b w/14b@8psi
                                  • darkelvisD Offline
                                    darkelvisD Offline
                                    darkelvis
                                    Ignition boxes don't produce a "hotter spark." And yes, a hotter spark WOULD hurt (which is why you want to run colder plugs).
                                      correct me if i am wrong.
                                      an upgraded ignition would help buy prevent spark blow out allowing you to run more gap on your plugs,
                                      edit: im dumb should have read it twice
                                      • XJHEADX Offline
                                        XJHEADX Offline
                                        an upgraded ignition would help buy prevent spark blow out allowing you to run less gap on your plugs,
                                        OK, you're wrong
                                        • bader3245B Offline
                                          bader3245B Offline
                                          bader3245
                                          You have it exactly backwards.
                                          2008 Ford F-150 FX4
                                          2006 Honda CRF250R
                                          2006 Honda CBR1000RR
