  4. Borg Warner S200 Honda D Series Setup
33 Posts 19 Posters 2.1k Views
    Got on the dyno yesterday w/ some decent results but we have pretty much found the limits of the stock cam, intake manifold, etc. Car was on a dyno dynamics dyno and put down 365 whp. They said their down has a correction factor of ~11% to a dynojet, @ that rate dynojet numbers should be around 405whp. We tried boost levels anywhere from 18-21 psi but anything over 18 psi provided minimal gains. Tried all the way 23-24 psi as well but the system was maxed and just ineffiecient and made no extra power over the lower boost levels. Next is to build a sheetmetal intake, install cam, and possible some mild head work and look for 450+whp.
        holy cow that awsome, time for some more parts and see what this beast can do
          The Honda says feed me more parts!
            ignition box possibly?
              It's not an ignition issue. Honda has a rather good stock ignition system.
                a hotter spark wouldnt hurt...
                • krzydrftr93K Offline
                  krzydrftr93
                  That is pretty sick. I wish i had that motor in my car.
                  Post some video up from the track once it gets out there
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                    whats the highest d series HP record? anyone ever hit 500?
                      krzydrftr93
                      theres a guy on honda tech with 502whp D-series
                      Matt
                      92 Civic HB
                      JDM d15b w/14b@8psi
                        link or pix?
                          krzydrftr93
                          cant find pics for that one...go to turbod16 There are some 450plus ones there.
                          ANd the guy on HT with the 500whp d is member TURBODCX. Sold the car for around 11,500
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                          • darkelvisD Offline
                            darkelvisD Offline
                            darkelvis
                            Ignition boxes don't produce a "hotter spark." And yes, a hotter spark WOULD hurt (which is why you want to run colder plugs).
                              correct me if i am wrong.
                              an upgraded ignition would help buy prevent spark blow out allowing you to run more gap on your plugs,
                              edit: im dumb should have read it twice
                              • XJHEADX Offline
                                XJHEADX Offline
                                an upgraded ignition would help buy prevent spark blow out allowing you to run less gap on your plugs,
                                OK, you're wrong
                                • bader3245B Offline
                                  bader3245B Offline
                                  bader3245
                                  You have it exactly backwards.
                                  2008 Ford F-150 FX4
                                  2006 Honda CRF250R
                                  2006 Honda CBR1000RR
                                    whoops i just reread that, run more plug gap whops, my bad
