  4. Governor
Governor
30 Posts 11 Posters 2.4k Views
  • K
    K
    on what vehicle?
    • LoveMachine69L
      LoveMachine69L
      LoveMachine69
      a 2001 Grand Prix GT
      2001 grand prix
      1982 S-10
      2001 cr-125 for sale $2000 or best offer
      • PSiedTSiP
        PSiedTSiP
        Get a DHP PCM. They are about $250 I believe.
        spanish-rice;237125 wrote:
        • K
          K
          i believe the jet chip for that application well do it also
          • LoveMachine69L
            LoveMachine69L
            LoveMachine69
            Im just not sure how to do any of that stuff but it sucks when my car tops out at 107
            2001 grand prix
            1982 S-10
            • PSiedTSiP
              PSiedTSiP
              DO NOT WASTE YOUR MONEY ON A JET CHIP!
              You can't do it yourself, you need to get a reflashed ECU from DHP like I said.
              http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GP3012&Product_Count=0&Category_Code=GPUNDER
              Seems its only $99 now.
                find someplace online that has roms for your car and I can (maybe) reflash your ecu for you.
                • LoveMachine69L
                  LoveMachine69L
                  LoveMachine69
                  Im probably going to buy than PCM thanks for your help PSiedTSI
                  2001 grand prix
                  1982 S-10
                  • Turbo5OhT
                    Turbo5OhT
                    Turbo5Oh
                    just dont go over 107 and dont die....its simple
                    • LoveMachine69L
                      LoveMachine69L
                      LoveMachine69
                      i just want to see how fast my car can go without the governor
                      2001 grand prix
                      1982 S-10
                      • JoKeRJ
                        JoKeRJ
                        JoKeR
                        a lot faster but is it really worth it????
                        :icon_jokercolor:
                        Black 99 z28
                        • LoveMachine69L
                          LoveMachine69L
                          LoveMachine69
                          as long as i dont get caught
                          2001 grand prix
                          1982 S-10
                          • PSiedTSiP
                            PSiedTSiP
                            The PCM does more than just remove the speed limiter.
                            • LoveMachine69L
                              LoveMachine69L
                              LoveMachine69
                              it raises the rev limiter to but what else does it do?
                              2001 grand prix
                              1982 S-10
                              • LoveMachine69L
                                LoveMachine69L
                                LoveMachine69
                                Doesn't anyone else ever just want to top out there car out of curiosity to see how fast it will go
                                2001 grand prix
                                1982 S-10
                                • PSiedTSiP
                                  PSiedTSiP
                                  Speed limiter removed
                                  3-1 and 4-2 skip shifts
                                  Transmission line pressure increased
                                  Shift points moved to 5800-6000 RPM
                                  Fan turn on points altered as follows:
                                  186 degree F turn on
                                  2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
                                  MAF calibration adjusted for proper year
                                  Fuel/spark adjustments as follows:
                                  Enrichens fuel delivery for critical problem areas
                                  Provides a consistent power gain across the entire power band
                                  Reduces spark retard (knock retard)
                                  Removes "40MPH wide open throttle lag" experienced with your stock PCM
                                  For most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
                                  • LoveMachine69L
                                    LoveMachine69L
                                    LoveMachine69
                                    For $100 i think thats a good deal
                                    2001 grand prix
                                    1982 S-10
                                    • K
                                      K
                                      ya, but dont go posting about it. at 117 in a grand prix is pretty fast, unless they rased it for the newerones
                                      • LoveMachine69L
                                        LoveMachine69L
                                        LoveMachine69
                                        i know the 2004 and up is higher and mines only 107 not 117
                                        2001 grand prix
                                        1982 S-10
                                        • PSiedTSiP
                                          PSiedTSiP
                                          112 for my 94
