Governor
Im just not sure how to do any of that stuff but it sucks when my car tops out at 107
DO NOT WASTE YOUR MONEY ON A JET CHIP!
You can't do it yourself, you need to get a reflashed ECU from DHP like I said.
Seems its only $99 now.
Im probably going to buy than PCM thanks for your help PSiedTSI
i just want to see how fast my car can go without the governor
as long as i dont get caught
it raises the rev limiter to but what else does it do?
Doesn't anyone else ever just want to top out there car out of curiosity to see how fast it will go
Speed limiter removed
3-1 and 4-2 skip shifts
Transmission line pressure increased
Shift points moved to 5800-6000 RPM
Fan turn on points altered as follows:
186 degree F turn on
2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
MAF calibration adjusted for proper year
Fuel/spark adjustments as follows:
Enrichens fuel delivery for critical problem areas
Provides a consistent power gain across the entire power band
Reduces spark retard (knock retard)
Removes "40MPH wide open throttle lag" experienced with your stock PCMFor most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
For $100 i think thats a good deal
i know the 2004 and up is higher and mines only 107 not 117
i see all the cars that go like 130 and i just want mine to be a little faster
