  4. Governor
Governor
30 Posts 11 Posters 2.3k Views
  • LoveMachine69L Offline
    LoveMachine69
    i just want to see how fast my car can go without the governor
    2001 grand prix
    1982 S-10
    2001 cr-125 for sale $2000 or best offer
    • JoKeRJ Offline
      JoKeRJ Offline
      JoKeR
      a lot faster but is it really worth it????
      :icon_jokercolor:
      Black 99 z28
        LoveMachine69
        as long as i dont get caught
        2001 grand prix
        1982 S-10
          The PCM does more than just remove the speed limiter.
            LoveMachine69
            it raises the rev limiter to but what else does it do?
            2001 grand prix
            1982 S-10
              LoveMachine69
              Doesn't anyone else ever just want to top out there car out of curiosity to see how fast it will go
              2001 grand prix
              1982 S-10
                Speed limiter removed
                3-1 and 4-2 skip shifts
                Transmission line pressure increased
                Shift points moved to 5800-6000 RPM
                Fan turn on points altered as follows:
                186 degree F turn on
                2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
                MAF calibration adjusted for proper year
                Fuel/spark adjustments as follows:
                Enrichens fuel delivery for critical problem areas
                Provides a consistent power gain across the entire power band
                Reduces spark retard (knock retard)
                Removes "40MPH wide open throttle lag" experienced with your stock PCM
                For most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
                  LoveMachine69
                  For $100 i think thats a good deal
                  2001 grand prix
                  1982 S-10
                    ya, but dont go posting about it. at 117 in a grand prix is pretty fast, unless they rased it for the newerones
                      LoveMachine69
                      i know the 2004 and up is higher and mines only 107 not 117
                      2001 grand prix
                      1982 S-10
                        112 for my 94
                          LoveMachine69
                          i see all the cars that go like 130 and i just want mine to be a little faster
                          2001 grand prix
                          1982 S-10
                            stirno
                            my cars stock limiter is 130.. without it now.. I run out of gear at 142. lame 😜
                            1998 Audi A4 1.8T // T-28 // Koni Coilovers // European Spec Headlights (Ecodes) w/HIDs
                            2007 VW GTI 2.0T // APR
                              tsk tsk tsk
                              You shouldn't be exceding the speed limit. 😄
                                my 95 was 117.
                                have yet to test it for sure and dont have a speedo that goes that high, the gearing on stock size tires is supposedly good for high 150's and with some taller tires ive have heard 170ish
                                  Your speedo must have been off or something because I believe all 1st gen w-bodies were 112.
                                  • youngin2nrY Offline
                                    youngin2nrY Offline
                                    youngin2nr
                                    Yeah brandon. I wouldnt talk about where you do this at.
                                    :3gears: -> :drink: -> :poon:
                                    • ticklemedalyT Offline
                                      ticklemedaly
                                      why do you need to go faster than 107 in a GP? you dont need to go fast in those at all. There is no need to go higher than that. I can "brag" all day about how my car can easily go 140 or more, but I really dont care. The car is to get to point A to B and without roads around here that will let you go that fast it really isn't necessary.
                                      XBL G-tag: TickleMeDaly83
                                        ^true that. i never maxxed out my GP, cause i saw no point in going that fast in a slow car.
                                          plus if you do get caught going fast then 100 in a 55 zone you can get aspeeding ticket and reckless driving. and if you get reckless driving you end up in jail for a bit and have court and maybe community service, speaking from experience too, it's not fun and you end up paying out the ass for insurance and what not
