Governor
Speed limiter removed
3-1 and 4-2 skip shifts
Transmission line pressure increased
Shift points moved to 5800-6000 RPM
Fan turn on points altered as follows:
186 degree F turn on
2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
MAF calibration adjusted for proper year
Fuel/spark adjustments as follows:
Enrichens fuel delivery for critical problem areas
Provides a consistent power gain across the entire power band
Reduces spark retard (knock retard)
Removes "40MPH wide open throttle lag" experienced with your stock PCMFor most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
For $100 i think thats a good deal
i know the 2004 and up is higher and mines only 107 not 117
i see all the cars that go like 130 and i just want mine to be a little faster
Yeah brandon. I wouldnt talk about where you do this at.
why do you need to go faster than 107 in a GP? you dont need to go fast in those at all. There is no need to go higher than that. I can "brag" all day about how my car can easily go 140 or more, but I really dont care. The car is to get to point A to B and without roads around here that will let you go that fast it really isn't necessary.
plus if you do get caught going fast then 100 in a 55 zone you can get aspeeding ticket and reckless driving. and if you get reckless driving you end up in jail for a bit and have court and maybe community service, speaking from experience too, it's not fun and you end up paying out the ass for insurance and what not
