  4. Governor
Governor
30 Posts 11 Posters 2.4k Views
  • LoveMachine69L
    LoveMachine69L
    LoveMachine69
    Doesn't anyone else ever just want to top out there car out of curiosity to see how fast it will go
    2001 grand prix
    1982 S-10
    2001 cr-125 for sale $2000 or best offer
    • PSiedTSiP
      PSiedTSiP
      Speed limiter removed
      3-1 and 4-2 skip shifts
      Transmission line pressure increased
      Shift points moved to 5800-6000 RPM
      Fan turn on points altered as follows:
      186 degree F turn on
      2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
      MAF calibration adjusted for proper year
      Fuel/spark adjustments as follows:
      Enrichens fuel delivery for critical problem areas
      Provides a consistent power gain across the entire power band
      Reduces spark retard (knock retard)
      Removes "40MPH wide open throttle lag" experienced with your stock PCM
      For most GP guys this is the most worthwhile mod they do. It usually gives around 12whp difference. Not bad for a stock NA car.
      spanish-rice;237125 wrote:
      • LoveMachine69L
        LoveMachine69L
        LoveMachine69
        For $100 i think thats a good deal
        2001 grand prix
        1982 S-10
        • K
          K
          ya, but dont go posting about it. at 117 in a grand prix is pretty fast, unless they rased it for the newerones
          • LoveMachine69L
            LoveMachine69L
            LoveMachine69
            i know the 2004 and up is higher and mines only 107 not 117
            2001 grand prix
            1982 S-10
            • PSiedTSiP
              PSiedTSiP
              112 for my 94
              • LoveMachine69L
                LoveMachine69L
                LoveMachine69
                i see all the cars that go like 130 and i just want mine to be a little faster
                2001 grand prix
                1982 S-10
                • S
                  S
                  stirno
                  my cars stock limiter is 130.. without it now.. I run out of gear at 142. lame 😜
                  1998 Audi A4 1.8T // T-28 // Koni Coilovers // European Spec Headlights (Ecodes) w/HIDs
                  2007 VW GTI 2.0T // APR
                  • MisterCMKM
                    MisterCMKM
                    tsk tsk tsk
                    You shouldn't be exceding the speed limit. 😄
                    thrash;315544 wrote:
                    Ford is back :)
                    • K
                      K
                      my 95 was 117.
                      have yet to test it for sure and dont have a speedo that goes that high, the gearing on stock size tires is supposedly good for high 150's and with some taller tires ive have heard 170ish
                      • PSiedTSiP
                        PSiedTSiP
                        Your speedo must have been off or something because I believe all 1st gen w-bodies were 112.
                        • youngin2nrY
                          youngin2nrY
                          youngin2nr
                          Yeah brandon. I wouldnt talk about where you do this at.
                          :3gears: -> :drink: -> :poon:
                          • ticklemedalyT
                            ticklemedalyT
                            ticklemedaly
                            why do you need to go faster than 107 in a GP? you dont need to go fast in those at all. There is no need to go higher than that. I can "brag" all day about how my car can easily go 140 or more, but I really dont care. The car is to get to point A to B and without roads around here that will let you go that fast it really isn't necessary.
                            XBL G-tag: TickleMeDaly83
                            • K
                              K
                              ^true that. i never maxxed out my GP, cause i saw no point in going that fast in a slow car.
                              • King RicerK
                                King RicerK
                                plus if you do get caught going fast then 100 in a 55 zone you can get aspeeding ticket and reckless driving. and if you get reckless driving you end up in jail for a bit and have court and maybe community service, speaking from experience too, it's not fun and you end up paying out the ass for insurance and what not
                                Trafik Jamz;299122 wrote:
