  4. Crx is still broken & I'm loosing my mind.
37 Posts 9 Posters 1.6k Views
    I've got an idea Bryce. Bring it to a shop and let them tackle it. I'm not sure if Ry is willing to do it. If not, see what Tufte says. It will save alot of heartache thats for sure. Sure it will cost a few bucks but in the end, it will be done and you wont end up killing any puppies over it.
      integra_gsr98 wrote:
      We have run stiff clutches in cable B series cars for 7+ years now and never had a problem. Just a random stupid question but is the trans completely flush with the block? Have you tried shimming the flywheel? What steps are you going through when you install the clutch and TOB?
      The tranny is flush with the block. M&J said there is no reason to shim the flywheel since it has only been re-done once with .007 taken off. I did get a .50 shim, however I don't really want to use it.
      What steps when I install my cluch? Brake cleaner all the parts, torque down everying thing in the correct pattern. Is there somthing special I should be doing? lol
        How much free play is there in the lever arm before you feel the throwout bearing touch the pressure plate?
        • ColinC Offline
          ColinC Offline
          Colin
          I've got him covered on the "professional" for beer thing...but 2 weeks is a long time.
            3/4th's play 1/4th engauglement. And that is what is wrong with the car, wayyy to much play.
              Have you tried shimming the arm?
                How would I go about doing that? I don't quite understand how that would help. I mean it was pulling it as far as possable, so far that my clutch pedal broke of. lol
                Someone on H-T thinks that it is the Thurst bearing, and the crank moved over a bit. What is your take on that possablilty Nick?
                  Your father in law rocks!:icon_thumleft:
                    You can check the thrust bearing by putting a pry bar behind the crank pully and prying out. If that doesn't work try it behind the flywheel going the other way and see if it moves.
                      So it should not move around at all? I tried a pry bar pushing the pully back into the case, and I could not get it to move? Mabye I should keep trying, that sounds like it could be the problem. ( However I hope it isnt, crosses fingers )
                      • ticklemedalyT Offline
                        ticklemedaly
                        what you are checking is crankshaft end play and there should be literally none (actually there is to be some but without a dial indicator to messure to the exact .0001", you wont know the right amount. What he is expecting you to see is any play, which would require new main bearings, or a rebuild.
                        XBL G-tag: TickleMeDaly83
                          Ok well I'm putting my car back together so I can move it, and bring it places.
                          I should get a medal, I just took out then insalled another transmission alone in 20 min. Got it down pat 😛
                          Edit: fuck spelling
                          • JN607J Offline
                            JN607J Offline
                            JN607
                            Damn...good job, my autoshop people last year took over a week just to replace a clutch...
                            2004 Scion xA
                            Airman First Class Nelson
                              I should get a metal, I just took out then insalled another transmission alone in 20 min. Got it down pat 😛
                              I think you mean Medal?!
                                The crx is fixed and back on the street!:icon_thumleft:
                                The pedal assembly turned out to be the problem. It kept bending from my Exedy cable cutch untill it broke. Then when I got it back together my starter went out, so I got a new starter in it.
                                It works great!🆒 Thanks for the help, and support guys.
