  4. Crx is still broken & I'm loosing my mind.
37 Posts 9 Posters 1.6k Views
    integra_gsr98 wrote:
    You have swapped flywheels as well? Sounds like it could be a step height issue.
    I thought the same thing! So I took it to M&J, and they ordered a brand new 90 Integra flywheel to compaire it too. Everything is on the dot. 😞
    I don't know the much about switching to hydro, or how that would help.
    • ticklemedalyT Offline
      ticklemedaly
      the most you would need to make sure about is whether or not a hydro tranny will bolt up to your block....if so, then you can get everything else to work. may make some pursuading but you'll need:
      tranny
      clutch master cylinder
      clutch slave sylinder
      and clutch pedal assembly for matching master if possible
      the hard lines can be hand bent to work. a hydro clutch will self compensate and wont need to have any adjustments done. I wonder if your cable is stretching out and causing all this tho?
      XBL G-tag: TickleMeDaly83
        tranny
        I am 99% sure it's not the cable, since I replaced it twice..
        About the hydro, that's a lot of cash. Ton of work. That would have to be a last resort.
          ticklemedaly
          when you replaced the cable, did you compare lenghts of old vs. new? it doesn't make any sense as to why it would be doing this unless the cable is stretching or the pressure plate has too much force.
          hydro would be a last resort, but you would still have a potential problem of this. I'm thinking either the cable is stretching easily or the bushings (due to the force of the pressure plate) on the pedal are too weak for the extra force. have you replaced the pedal assembly only once so far? if so, check the bushings to see how much play you have now compared to when you put it in. If you have a lot of play now, if any for that matter, I say that is the source of the problem due to the extra force of the pressure plate....for some odd reason tho 😕
            I compaired the lenghts, it did not strech. I have only replaced the assembly once, and if I have to do it again I'm going to murder puppies. That was not easy to find or replace.
            The problem is with the travel of the arm, not the cable. The cable is doing it's job. I tried a used 100% stock clutch/PP, and had the same problem with TOB travel.
            Thanks for all the head scraching Ry & Gsr!:icon_thumleft:
              ticklemedaly
              im narrowing it down to the arm assembly. take a look at the assembly as soon as you can and see if you have play in the bushings/pivot area. that wearing out will cause it to not pivot properly and create the needed adjustments in the cable.
                We have run stiff clutches in cable B series cars for 7+ years now and never had a problem. Just a random stupid question but is the trans completely flush with the block? Have you tried shimming the flywheel? What steps are you going through when you install the clutch and TOB?
                  I've got an idea Bryce. Bring it to a shop and let them tackle it. I'm not sure if Ry is willing to do it. If not, see what Tufte says. It will save alot of heartache thats for sure. Sure it will cost a few bucks but in the end, it will be done and you wont end up killing any puppies over it.
                    The tranny is flush with the block. M&J said there is no reason to shim the flywheel since it has only been re-done once with .007 taken off. I did get a .50 shim, however I don't really want to use it.
                    What steps when I install my cluch? Brake cleaner all the parts, torque down everying thing in the correct pattern. Is there somthing special I should be doing? lol
                      How much free play is there in the lever arm before you feel the throwout bearing touch the pressure plate?
                      • ColinC Offline
                        ColinC Offline
                        Colin
                        I've got him covered on the "professional" for beer thing...but 2 weeks is a long time.
                          3/4th's play 1/4th engauglement. And that is what is wrong with the car, wayyy to much play.
                            Have you tried shimming the arm?
                              How would I go about doing that? I don't quite understand how that would help. I mean it was pulling it as far as possable, so far that my clutch pedal broke of. lol
                              Someone on H-T thinks that it is the Thurst bearing, and the crank moved over a bit. What is your take on that possablilty Nick?
                                Your father in law rocks!:icon_thumleft:
                                  You can check the thrust bearing by putting a pry bar behind the crank pully and prying out. If that doesn't work try it behind the flywheel going the other way and see if it moves.
                                    So it should not move around at all? I tried a pry bar pushing the pully back into the case, and I could not get it to move? Mabye I should keep trying, that sounds like it could be the problem. ( However I hope it isnt, crosses fingers )
                                      ticklemedaly
                                      what you are checking is crankshaft end play and there should be literally none (actually there is to be some but without a dial indicator to messure to the exact .0001", you wont know the right amount. What he is expecting you to see is any play, which would require new main bearings, or a rebuild.
                                        Ok well I'm putting my car back together so I can move it, and bring it places.
                                        I should get a medal, I just took out then insalled another transmission alone in 20 min. Got it down pat 😛
                                        Edit: fuck spelling
                                        • JN607J Offline
                                          JN607J Offline
                                          JN607
                                          Damn...good job, my autoshop people last year took over a week just to replace a clutch...
                                          2004 Scion xA
                                          Airman First Class Nelson
