  4. Fired the 6.0L tonight!
21 Posts 9 Posters 1.2k Views
    is this going to be the rotary smasher? 🙂
    • XJHEADX Offline
      XJHEADX Offline
      Grr wrote:
      it doesnt have oil or a damn filter on it even, . Maybe next week i will be able to have it start and run on its own accord for a few minutes and see what kind of issues i have to deal with next. Gary
      :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
      I would guess maybe bad bearings???
        I agree. You actually fired it with no oil in it? That is retarded.
          Congrats on getting it fired, but ouch on the bearings for no oil. Hopefully the assembly lube did it's job.
            well i really dont think that turning it over for 4 or 5 revolutions really has any type of drastic effect on bearing life. not like i sat there and rev'ed on it for 5 minutes. really guys get a clue, people have run motors without any oil in them for 10 minutes or better just for shits and giggles. Also, its really no different than every time you go outside and start your car in the morning and it takes 5 revolutions to pressurise the oiling system. It honestly isnt something that does not occur to every motor numerous times in its life in the first place.
            Gary
              slowvo
              ive worked on cars that left the shop with no oil, drove 50 miles, drove back with the oil light on without any problems (30k down the road)
              it happens quite a bit acually...damn lube bitch!
              • XJHEADX Offline
                XJHEADX Offline
                Gary
                OK:icon_salut:
                • StangerBanger96S Offline
                  StangerBanger96
                  Especially if the engine was ran with synthetic oil. I can't find a link to it but I know there was a test on 2 engines, 1 had only used synthetic and the other only dino oil. They drained them down and ran them oilless, it was like 10min and the dino seized while the synthetic kept going for quite awhile.
                    Still doesn't mean there wasn't damage to the bearings. I don't know why you'd risk it on a motor you plan on making big power with. It's not a D series honda.
                      StangerBanger96
                      Like he said, if it only spun 4 or 5 revolutions and had a small amount of lube on it then it's going to be close to a hard startup. Just like a car that's been stored over winter and starts up for the first time will experience.
                        I always prime the oil system in a vehicles thats been sitting more than a month before I fire it up...
                          also i would have primed it in the first place, but guess what, LS motors have a crank driven oil pump and the only way to prime them is?, you guessed it, turning the damn thing over. So i guess all the shops out there that build motors are fuckin morons for turning the engine over for ten seconds while the oil system pressurises, right? YEP, i think those 4 or 5 combustion events took the babbitt right off the bearings and i have to rebuild it now. Oh but i forgot, the whole point of this board is to bash anything that isnt yours.
                          Gary
                            slowvo
                            How do you do this?
                            • XJHEADX Offline
                              XJHEADX Offline
                              slowvo wrote:
                              How do you do this?
                              Some motors have the distributor drive a shaft that connects to the oil pump.
                              You mark dist setting and rotor setting then you pull it out and either use a speed wrench(hard) or get a drill. Fords spin in reverse not too sure on chebby rotation clockwise I think...
                              Oh something I also saw
                              Subject: Re: Oil Priming an LT1?
                              Date: Tue, 10 Aug 1999 18:03:00 EDT
                              Newsgroups: rec.autos.rod-n-custom
                              [email protected] wrote:
                              Yeap, what I was thinking to do was to squirt some oil into the piston
                              chambers of all eight and disconnect the fuel pump relay (pull the
                              fuse) and crank it for a while. But this, I think, could still be to
                              hard on an engine that has been sleeping for so long. I was looking
                              for other solutions. Any of you guys ever heard of preassure priming?
                              I don't know how it works, but I believe it involves compressed air.
                              And of course there is the external electric pump, but last time I
                              checked it was in the upper $400. (not an option).
                              I have a rig I use on all new engine starts. It consists of a
                              stainless steel 5 gal Coke syrup can equipped with a schrader air
                              valve, a hose, a ball valve and a check valve. The tank is filled
                              with 2 gallons of oil, pressurized to 100 psi and the end of the
                              hose with the check valve and ball valve is screwed into the oil
                              sender port. Or in the unusual event the sender isn't easily
                              accessible, I use a modified freon side tapper to pierce the side of
                              an oil filter and tap in there.
                              In use, the can is sat on refrigerant scales (just because I have
                              'em), the ball valve turned on and when the scales indicate about a
                              gallon of oil has flowed in the engine and oil is visible through
                              the oil filler hole, the engine is fired. The oil is allowed to
                              continue to flow until the scales indicate the proper quantity of
                              oil is in the engine. The 100 psi air pressure in the can will
                              override the oil pump and lift its relief valve at fast idle. The
                              check valve prevents any oil from being pumped back to the tank in
                              the event the air pressure is too low. When the correct amount of
                              oil is in the engine, turn the ball valve and continue with the cam
                              break-in procedure.
                              The advantage of this procedure is a) it's cheap - the tank can be
                              had at flea markets or even from Coke, b) it fills the filter, the
                              galleys and primes the pump, c) one can verify proper oil flow
                              BEFORE firing the engine for the first time, and d) you don't have
                              to fool with any sort of priming tool and the attendant risk of
                              damage to the engine or of dropping something down the hole.
                              If you don't have scales, you can simply put the correct amount of
                              oil in the tank and flow it in until you see bubbles in the line
                              indicating the tank is getting empty. I use the fabric reinforced
                              plastic hose that the coke company uses. If that is not available,
                              one can use the clear fabric reinforced PVC hose available at Lowes,
                              Home Depot and the like.
                              • XJHEADX Offline
                                XJHEADX Offline
                                http://www.jasperengines.com/pdf/FordEngineOilPrimingTB.pdf
                                  slowvo
                                  uhh...i know how to do it, and have before.
                                  just wanted to know the quick way thats done whenever an engine sits for over a month.
                                  sounds like a lot of work to me..
                                  • XJHEADX Offline
                                    XJHEADX Offline
                                    You can crank it over too. Short spurts. Just make sure you aren't dumping fuel into the engine. Most engines will not dump fuel at WOT when cranking.
                                      I just unhook the injectors and then crank away with the plugs out. Taking the plugs out makes it so there is no force put on the bearings while you crank it.
                                      • D Offline
                                        D Offline
                                        dynotune
                                        the best way to do the ls motor is to pack the pump when you assemble the engine (with assy lube, pet jelly, whatever). Then crank it with the plugs out until you see pressure, and tadda! yer done. But if you crank it with no oil in it, the pump can/ will lose it's prime pretty easy. I've done quite a few of these, and this seems to work the best. No, you didn't hurt anything when you did that obviously, but it didn't help. Good luck... I got a 6.0L (402) going in a C5 right now also, but equipped with a pair of 67s :icon_thumright:
                                        DynoTune Speed & Performance
                                        Mobile chassis dyno service
                                        www.dynotuneusa.com
                                        (605) 753-1101
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          :icon_puke_r:
