  4. D15b2 Motor and trans
23 Posts 7 Posters 2.4k Views
    i'de take 100 for the motor and 100 for tranny clutch axles ECU etc.
      Could I Not Use My Tranny And Axles For This? How Much To Get That Ecu Also?
        Yes you could use your tranny and axles, you would have to use your tranny. That ecu won't do anything for you either unless you have another use.
          yeah you're right, i just realized that. how hard is it to mini-me a motor? ive never even looked into it. its really just switching the heads right? what headbolts do i use and what timing belt?
            match the timing belt to the head used... **** head use a z6 belt.... also make sure you remove the oil resticter out of the block....
              is that basically it? thats what i thought, lol it just sounds so simple.
                wells if thats the case joel just tell me a time to come look/pick up.
                  Oh, and if you are going to used aftermarket pistons and rods in it, i don't think they will work.
                  • karter_2_22K Offline
                    karter_2_22
                    ill take the trany for 100 than, that is if there are no grinds
                      No Aftermarket Pistons/rods, Just A Dd Motor To Cruise On
                        Ok, then it will be fine, but if you are gonna boost it, keep it low unless you wanna replace it soon. It probly won't take much more than 160-180 at best.
                          Motor tranny ECU and Axles sold for 200... sorry guys.
                            no way, your kidding
