  4. D15b2 Motor and trans
23 Posts 7 Posters 2.4k Views
    yeah you're right, i just realized that. how hard is it to mini-me a motor? ive never even looked into it. its really just switching the heads right? what headbolts do i use and what timing belt?
      match the timing belt to the head used... **** head use a z6 belt.... also make sure you remove the oil resticter out of the block....
        is that basically it? thats what i thought, lol it just sounds so simple.
          wells if thats the case joel just tell me a time to come look/pick up.
            Oh, and if you are going to used aftermarket pistons and rods in it, i don't think they will work.
            • karter_2_22K Offline
              karter_2_22
              ill take the trany for 100 than, that is if there are no grinds
                No Aftermarket Pistons/rods, Just A Dd Motor To Cruise On
                  Ok, then it will be fine, but if you are gonna boost it, keep it low unless you wanna replace it soon. It probly won't take much more than 160-180 at best.
                    Motor tranny ECU and Axles sold for 200... sorry guys.
                      no way, your kidding
