  4. Supercharged 3800
Supercharged 3800
20 Posts 9 Posters 1.7k Views
  • K
    K
    MisterCMK;156160 wrote:
    If the bearing went out it should make a lot of noise but still should produce boost
    Ya, until it seizes up. But I know mike knows alot about cars and wouldn't ever let it get that far.
    • dubbsyD
      dubbsyD
      well if it's not boosting the blower either isn't spinning or it's leaking boost somewhere. Is the blower pulley keyed onto the shaft or is it a hub setup? Pulley isn't slipping on the shaft is it? Or, belt slipping on the pulley? (I would expect in a stock setup it'd only do that if the bearings were shot)
      • capitljC
        capitljC
        capitlj
        There is some kinda boost regulator thingamabob (actual technical term) on the passenger side up front its held down with a couple of bolts i think. This is one of the more common places for the 3.8 SC motor to have a problem. My brothers GTP had teh same problem you just gotta loosen the bolts a bit push it down as hard as you can then tighten the bolts again. There is more involed but its been a long time since i did it and i don't remember much but you should be able to find the procedure on those forums I would think.
        Mitch Hedberg wrote:
        2004 Impala LS 3.8
        • wa2fastcamaroW
          wa2fastcamaroW
          wa2fastcamaro
          I didn't get time to look at it, but my supercharger isn't working. Makes no bad noises, the bypass valve is working perfect, so I am quite confused. A guy on the bonneville club forum said to check the couplerin the supercharger, its a plastic coupler that connects the nose shaft to the supercharger screws. Apperently it only lasts 70-120k miles and since my car has over 180K it may have broken and thus my superchager won't work. So I am going to take the nose section off of it monday or tuesday.
          I was mainly wondering if anyone had any experience with these engines.
          Mike
          Boys and Their Toys Auto
          Phone: 701-371-5615
          E-mail: [email protected]
          • wa2fastcamaroW
            wa2fastcamaroW
            wa2fastcamaro
            well I found my problem, someone gutted my supercharger before I baught the car. 😞
            here's pics
            Phone: 701-371-5615
            • inspector01I
              inspector01I
              That sucks.......
              Oh btw, i know where thers is a supercharger at for this motor.....
              • K
                K
                you never noticed no boost before you bought it?
                That totally sucks.
                • 94NDTA9
                  94NDTA9
                  I' sure he got a killer deal on it anyways. Now this gives you an excuse to do a whipple upgrade.
                  • MisterCMKM
                    MisterCMKM
                    wow, why would someone gut the blower like that?
                    thrash;315544 wrote:
                    Ford is back :)
                    • 94NDTA9
                      94NDTA9
                      parts I guess, or the blower broke, and they gutted it so it would still run.
                      I don't know, it's gay.
                      • wa2fastcamaroW
                        wa2fastcamaroW
                        wa2fastcamaro
                        That totally sucks.
                        I baught it at a auction, and didn't get to drive it before buying it. I did get a pretty good deal and am very happy with the car. I always figured the boost controler was bad, and I finally had time to go through the car, I guess it was a little more. I found a SC for $150 so that should solve my problem.
                        Phone: 701-371-5615
                        • capitljC
                          capitljC
                          capitlj
                          At least you found one for cheap thats a bum deal though but it did make me giggle a bit sorry.
                          2004 Impala LS 3.8
