  4. Supercharged 3800
Supercharged 3800
20 Posts 9 Posters 1.7k Views
  • ghostG
    ghostG
    ghost
    Try out some of these forums:
    www.clubgp.com
    www.mnclubgp.com
    www.midwest3800.com
    www.dakotawbody.com
    Hope you can get your answer from one of these.:icon_compress:
    2002 Grand Prix GTP
    legacy imagelegacy image
    • wa2fastcamaroW
      wa2fastcamaroW
      wa2fastcamaro
      wa2fastcamaro;156108 wrote:
      Anyone have any experience with the supercharged 3800 series engines? My 93 bonneville isn't boosting and I want to find out why.
      Ya I know about the forums, I am members of many of them, but wanted to see if any was local to help.
      Boys and Their Toys Auto
      Phone: 701-371-5615
      E-mail: [email protected]
      • ghostG
        ghostG
        ghost
        sorry...some people from mnclubgp.com and dakotawbody.com are local. So I thought you might want to post there as well since they are focused more on the 3800. My bad... Hope someone can help ya:icon_compress:
        2002 Grand Prix GTP
        • beachbum_jonB
          beachbum_jonB
          beachbum_jon
          i have a friend with i think its a 03 bonnie sc, and he said he wasnt boosting at all, took it into the dealer and they said it was something with the pully on the supercharger, i donno if he knew what he was talking about or not, but its fixed now...
          not sure if that helps at all...but i tried
          -John Adams, 1735-1826-
          • MisterCMKM
            MisterCMKM
            Is the bypass valve stuck?
            thrash;315544 wrote:
            Ford is back :)
            • K
              K
              It would be pretty hard to not have noticed it, but the bearings to go out on the superchargers quite often. But I know you would have noticed that before it was to late. The car isn't throwing any codes is it?
              • MisterCMKM
                MisterCMKM
                If the bearing went out it should make a lot of noise but still should produce boost
                Ford is back :)
                • K
                  K
                  Ya, until it seizes up. But I know mike knows alot about cars and wouldn't ever let it get that far.
                  • dubbsyD
                    dubbsyD
                    well if it's not boosting the blower either isn't spinning or it's leaking boost somewhere. Is the blower pulley keyed onto the shaft or is it a hub setup? Pulley isn't slipping on the shaft is it? Or, belt slipping on the pulley? (I would expect in a stock setup it'd only do that if the bearings were shot)
                    • capitljC
                      capitljC
                      capitlj
                      There is some kinda boost regulator thingamabob (actual technical term) on the passenger side up front its held down with a couple of bolts i think. This is one of the more common places for the 3.8 SC motor to have a problem. My brothers GTP had teh same problem you just gotta loosen the bolts a bit push it down as hard as you can then tighten the bolts again. There is more involed but its been a long time since i did it and i don't remember much but you should be able to find the procedure on those forums I would think.
                      Mitch Hedberg wrote:
                      2004 Impala LS 3.8
                      • wa2fastcamaroW
                        wa2fastcamaroW
                        wa2fastcamaro
                        I didn't get time to look at it, but my supercharger isn't working. Makes no bad noises, the bypass valve is working perfect, so I am quite confused. A guy on the bonneville club forum said to check the couplerin the supercharger, its a plastic coupler that connects the nose shaft to the supercharger screws. Apperently it only lasts 70-120k miles and since my car has over 180K it may have broken and thus my superchager won't work. So I am going to take the nose section off of it monday or tuesday.
                        I was mainly wondering if anyone had any experience with these engines.
                        Mike
                        Phone: 701-371-5615
                        • wa2fastcamaroW
                          wa2fastcamaroW
                          wa2fastcamaro
                          well I found my problem, someone gutted my supercharger before I baught the car. 😞
                          here's pics
                          Phone: 701-371-5615
                          • inspector01I
                            inspector01I
                            That sucks.......
                            Oh btw, i know where thers is a supercharger at for this motor.....
                            • K
                              K
                              you never noticed no boost before you bought it?
                              That totally sucks.
                              • 94NDTA9
                                94NDTA9
                                I' sure he got a killer deal on it anyways. Now this gives you an excuse to do a whipple upgrade.
                                • MisterCMKM
                                  MisterCMKM
                                  wow, why would someone gut the blower like that?
                                  Ford is back :)
                                  • 94NDTA9
                                    94NDTA9
                                    parts I guess, or the blower broke, and they gutted it so it would still run.
                                    I don't know, it's gay.
                                    • wa2fastcamaroW
                                      wa2fastcamaroW
                                      wa2fastcamaro
                                      That totally sucks.
                                      I baught it at a auction, and didn't get to drive it before buying it. I did get a pretty good deal and am very happy with the car. I always figured the boost controler was bad, and I finally had time to go through the car, I guess it was a little more. I found a SC for $150 so that should solve my problem.
                                      Phone: 701-371-5615
                                      • capitljC
                                        capitljC
                                        capitlj
                                        At least you found one for cheap thats a bum deal though but it did make me giggle a bit sorry.
                                        2004 Impala LS 3.8
