  4. Supercharged 3800
Supercharged 3800
20 Posts 9 Posters 1.2k Views
  • wa2fastcamaroW Offline
    wa2fastcamaro
    Anyone have any experience with the supercharged 3800 series engines? My 93 bonneville isn't boosting and I want to find out why.
    Boys and Their Toys Auto
    Phone: 701-371-5615
    E-mail: [email protected]
    • ghostG Offline
      ghostG Offline
      ghost
      Try out some of these forums:
      www.clubgp.com
      www.mnclubgp.com
      www.midwest3800.com
      www.dakotawbody.com
      Hope you can get your answer from one of these.:icon_compress:
      2002 Grand Prix GTP
      legacy imagelegacy image
        wa2fastcamaro
        Ya I know about the forums, I am members of many of them, but wanted to see if any was local to help.
        Phone: 701-371-5615
        • ghostG Offline
          ghostG Offline
          ghost
          sorry...some people from mnclubgp.com and dakotawbody.com are local. So I thought you might want to post there as well since they are focused more on the 3800. My bad... Hope someone can help ya:icon_compress:
          2002 Grand Prix GTP
          • beachbum_jonB Offline
            beachbum_jon
            i have a friend with i think its a 03 bonnie sc, and he said he wasnt boosting at all, took it into the dealer and they said it was something with the pully on the supercharger, i donno if he knew what he was talking about or not, but its fixed now...
            not sure if that helps at all...but i tried
            -John Adams, 1735-1826-
              Is the bypass valve stuck?
                It would be pretty hard to not have noticed it, but the bearings to go out on the superchargers quite often. But I know you would have noticed that before it was to late. The car isn't throwing any codes is it?
                  If the bearing went out it should make a lot of noise but still should produce boost
                    Ya, until it seizes up. But I know mike knows alot about cars and wouldn't ever let it get that far.
                    • dubbsyD Offline
                      dubbsyD Offline
                      well if it's not boosting the blower either isn't spinning or it's leaking boost somewhere. Is the blower pulley keyed onto the shaft or is it a hub setup? Pulley isn't slipping on the shaft is it? Or, belt slipping on the pulley? (I would expect in a stock setup it'd only do that if the bearings were shot)
                      • capitljC Offline
                        capitljC Offline
                        capitlj
                        There is some kinda boost regulator thingamabob (actual technical term) on the passenger side up front its held down with a couple of bolts i think. This is one of the more common places for the 3.8 SC motor to have a problem. My brothers GTP had teh same problem you just gotta loosen the bolts a bit push it down as hard as you can then tighten the bolts again. There is more involed but its been a long time since i did it and i don't remember much but you should be able to find the procedure on those forums I would think.
                        > Mitch Hedberg wrote:
                        2004 Impala LS 3.8
                          wa2fastcamaro
                          I didn't get time to look at it, but my supercharger isn't working. Makes no bad noises, the bypass valve is working perfect, so I am quite confused. A guy on the bonneville club forum said to check the couplerin the supercharger, its a plastic coupler that connects the nose shaft to the supercharger screws. Apperently it only lasts 70-120k miles and since my car has over 180K it may have broken and thus my superchager won't work. So I am going to take the nose section off of it monday or tuesday.
                          I was mainly wondering if anyone had any experience with these engines.
                          Mike
                          Phone: 701-371-5615
                            wa2fastcamaro
                            well I found my problem, someone gutted my supercharger before I baught the car. 😞
                            here's pics
                            Phone: 701-371-5615
                              That sucks.......
                              Oh btw, i know where thers is a supercharger at for this motor.....
                                you never noticed no boost before you bought it?
                                That totally sucks.
                                • 94NDTA9 Offline
                                  94NDTA9 Offline
                                  I' sure he got a killer deal on it anyways. Now this gives you an excuse to do a whipple upgrade.
                                    wow, why would someone gut the blower like that?
                                    • 94NDTA9 Offline
                                      94NDTA9 Offline
                                      parts I guess, or the blower broke, and they gutted it so it would still run.
                                      I don't know, it's gay.
                                        wa2fastcamaro
                                        That totally sucks.
                                        I baught it at a auction, and didn't get to drive it before buying it. I did get a pretty good deal and am very happy with the car. I always figured the boost controler was bad, and I finally had time to go through the car, I guess it was a little more. I found a SC for $150 so that should solve my problem.
                                        Phone: 701-371-5615
                                        • capitljC Offline
                                          capitljC Offline
                                          capitlj
                                          At least you found one for cheap thats a bum deal though but it did make me giggle a bit sorry.
                                          2004 Impala LS 3.8
