Tint removal.
Its really easy, i just did it to my Civic cause i bought it with like a home made tint job lol. Just take a razor blade and begin to peel down from the top of the window, once you have enough off to grab, just pull it off slowly, then goo gone the hell out of the windows to clean them, this takes forever to clean but it worked, hope that helped
you can take it to any place that tints windows and they should remove it for a price.
do u know how old the tint is? when it gets old and brittle its a huge pain in the ass. but if it comes off rather easy just peel it and use some type of adhiesive remover
also i hope ur not trying to remove it from a rear window with defroster lines, other wise say bye bye to defrost
Yeah don't remove it on your own from the rear windows.
I had to remove my tint awhile back and what I did was cut a black garbage bag to the size of the window. Spray the bag and window with windex then place the bag on the window. Park the car so the windows facing the sun or since this weather sucks you could probably use a hair dryer or something to heat it up for a couple minutes. Then take it off and use a razor to start peeling it off...if you let it sit long enough it should peel off almost completely with not much sticking. Then use steel wool to remove the rest of the glue that sticks.
When I removed mine, a razor blade worked for everything besides the rear window (defrost). I was not sure what to do there, so I went to the local auto paint & supply store and they gave me this stuff to use. It smelled horrible, and they stressed to me not to get any on my skin. But it got the tint off in a matter of minutes. I can't remember for the life of me what it was called though.
When I did my grand prix, I did all with windows in under 20min. My 240, me and my dad spend well over 10hours on it. It was at least 8 years old, 2 layers of tint, and then the factory clear shit. We took out the windows we could and the set them flat and soaked them with paint and decal remover, it took a couple times, but got it off. I also just replaced the rear window with one that did not have tint.
Flamethrower, kicks ass, but not so good for the interior.
Not meaning to jack this thread at all but what do you guys use to get tint ON? I have heard baby oil and Windex.
94NDTA;163055 wrote:
Anywhere in town do it? If not, how is it done? Razor blade and rubbing alcohol?pour some captain on it and then lick it right off!
Removing tint from windows...
-Peel actual film off(adhesive will still be on the window)
-Use foaming window cleaner and a razorblade. Clean adhesive off window.
Rear windows...
Peel film off
-use foaming window cleaner and steel wool. if that doesnt work, use a normal rag/towel and adhesive remover(buy industrial shit)
