  4. Tint removal.
Tint removal.
18 Posts 12 Posters 957 Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    Anywhere in town do it? If not, how is it done? Razor blade and rubbing alcohol?
    • C Offline
      C Offline
      CivicEX7777777
      Its really easy, i just did it to my Civic cause i bought it with like a home made tint job lol. Just take a razor blade and begin to peel down from the top of the window, once you have enough off to grab, just pull it off slowly, then goo gone the hell out of the windows to clean them, this takes forever to clean but it worked, hope that helped
      2007 Pontiac G5
      2007 Yamaha C3
      2002 Oldsmobile Alero
      1994 Nissan Sentra
      • 94NDTA9 Offline
        94NDTA9 Offline
        sweet.
          A little heat might help too
            you can take it to any place that tints windows and they should remove it for a price.
            • Turbo5OhT Offline
              Turbo5OhT Offline
              Turbo5Oh
              do u know how old the tint is? when it gets old and brittle its a huge pain in the ass. but if it comes off rather easy just peel it and use some type of adhiesive remover
              also i hope ur not trying to remove it from a rear window with defroster lines, other wise say bye bye to defrost
              • StangerBanger96S Offline
                StangerBanger96
                Yeah don't remove it on your own from the rear windows.
                I had to remove my tint awhile back and what I did was cut a black garbage bag to the size of the window. Spray the bag and window with windex then place the bag on the window. Park the car so the windows facing the sun or since this weather sucks you could probably use a hair dryer or something to heat it up for a couple minutes. Then take it off and use a razor to start peeling it off...if you let it sit long enough it should peel off almost completely with not much sticking. Then use steel wool to remove the rest of the glue that sticks.
                • StormwalkerS Offline
                  Stormwalker
                  When I removed mine, a razor blade worked for everything besides the rear window (defrost). I was not sure what to do there, so I went to the local auto paint & supply store and they gave me this stuff to use. It smelled horrible, and they stressed to me not to get any on my skin. But it got the tint off in a matter of minutes. I can't remember for the life of me what it was called though.
                  www.tcstangs.com
                    When I did my grand prix, I did all with windows in under 20min. My 240, me and my dad spend well over 10hours on it. It was at least 8 years old, 2 layers of tint, and then the factory clear shit. We took out the windows we could and the set them flat and soaked them with paint and decal remover, it took a couple times, but got it off. I also just replaced the rear window with one that did not have tint.
                    • Sweet-WRX-LovinS Offline
                      Sweet-WRX-Lovin
                      Flamethrower, kicks ass, but not so good for the interior.
                      One time...
                        Aren't you drunk yet?
                          i'll do all your windows for 50 bucks. and I promise the rear window will still defrost when i'm done, detailers secret!
                          • thurmanmermanT Offline
                            thurmanmerman
                            Not meaning to jack this thread at all but what do you guys use to get tint ON? I have heard baby oil and Windex.
                            > Parker;299126 wrote:
                            • killer69penguinK Offline
                              killer69penguin
                              pour some captain on it and then lick it right off!
                              1993 3000GT VR4
                                Isn't that what you use when you are touc.....
                                • 94NDTA9 Offline
                                  94NDTA9 Offline
                                  It's not my car. I'll see if I can get it off myself.
                                    Start with some 60 grit sand paper...
                                      Removing tint from windows...
                                      -Peel actual film off(adhesive will still be on the window)
                                      -Use foaming window cleaner and a razorblade. Clean adhesive off window.
                                      Rear windows...
                                      Peel film off
                                      -use foaming window cleaner and steel wool. if that doesnt work, use a normal rag/towel and adhesive remover(buy industrial shit)
