  4. 136 PSI turbocharger.....
22 Posts 11 Posters 3.4k Views
  • beachbum_jonB
    beachbum_jonB
    beachbum_jon
    that is probably because it is easier, but i never knew they put that motor in the f650s, that would probably explain why when i was looking under the hood of a 02 f250 and they had the belt configuration printed on the radiator shroud for a 5.9l cummins...
    -John Adams, 1735-1826-
    • F
      F
      Fitzy
      Most of the big power diesels are stock blocks just head studs and headgaskets.
      2002 Honda S2000
      2006 Dodge Ram CTD
      • K
        K
        There are 2 trucks in the area that I know about that have built motors with a bunch of goodies.
        You can make power really really quick for a cheaper price on a diesel then a gas truck(chip, intake, exhaust). But when you want to start going for the like 500ish+ it get extremely expensive extremely fast. I know modding anything is expensive especailly when going for lots of power. You have to remember diesels dont rev near as high as gas motors so it takes more of the factors that gain power then other cars.
        • 2gTSIGUY2
          2gTSIGUY2
          2gTSIGUY
          Anyone know if he was running propane in that rig?
          • K
            K
            ^It would not suprise me.
            I talked to my dad, he said both the hardcore modded trucks in the area are running fully built motors(custom built injection pumps, camshafts....) one is 630whp and the other is 718whp. He also said even at that level you need a built motor.
            • zbrownZ
              zbrownZ
              that is the same motor used in the 3/4 and 1 ton 12 valve dodges.... (94-98.5)
              the first gen motors (89-93) were nearly identical cept small changes like the position of the top piston ring and they didnt use an inline Bosh pump like the 2nd 12 valve pickups did, they used a rotary style pump
              In 98.5 they switched to the 24 valve which is essentially the same block with a 24valve head and different fueling
              and i would not be suprised in the least if that is a stock block .... at all
              usually what is done is flow work on the head and O-ringing the head, and studs
              do you realize how easy it is to get 800hp/1200fts + out of a 12 valve or 24 valve?? the problem is building your drivetrain to sustain this
              once more is learned about the common rail system the power potential will be that much more
              stock equipment in the f650 and a 3/4 ton dodge...... seems like an easy choice:icon_scratch:
              • zbrownZ
                zbrownZ
                uhh i def dont know about that..... i read religiously on a hardcore cummins forum.... and 450 is no problem even on a tiny ass 9cm2 hx35
                my pickup would be at 550 wheel easily with a set of injectors, delivery valves, and governor springs and no head work or anytyhing... i cant do this becasue the converter and trany will not support the TQ created
                • zbrownZ
                  zbrownZ
                  yes he is exactly correct....+ oringed head
                  sorry got excited a little... but that is the other thing i like aside from rotarys..... mechanical pump cummins
                  • JoelJ
                    JoelJ
                    hahaha zach on his tangents
                    • MisterCMKM
                      MisterCMKM
                      What kind of truck do you have?
                      thrash;315544 wrote:
                      Ford is back :)
                      • P
                        P
                        Typically the 24 valves are putting down 425-460hp and 800-860 ft lbs w/ just a programmer and exhaust.
                        I ran my truck twice last year stock 16.3, programmer and exhaust 14.7. 7200lbs w/ me in it, definate drastic power increase w/ minimal mods.
                        • zbrownZ
                          zbrownZ
                          a 95 12valve with 5" exhaust and fuel plate
