  4. 136 PSI turbocharger.....
22 Posts 11 Posters 3.4k Views
  • P
    P
    No, last years winner went 10.23.
    • 94NDTA9
      94NDTA9
      Oh, my bad.
      • torbsT
        torbsT
        Is this on totally stock longblocks nick?
        • K
          K
          ^Would highly doubt it. Those are tough motors, but I dont think they are that tough, 1000hp in a diesel is way more impressive to me then 1000hp in a gas car.
          • bubbaB
            bubbaB
            ^ I always thought diesel's would be a lot easier to make that kind of power. One thing i've always wanted to build is a 2500 Ram with a 24V cummins and 6 spd.
            • 94NDTA9
              94NDTA9
              Same here. I always though it was WAY more easier to make turbo deisels with big power.
              • beachbum_jonB
                beachbum_jonB
                beachbum_jon
                that is probably because it is easier, but i never knew they put that motor in the f650s, that would probably explain why when i was looking under the hood of a 02 f250 and they had the belt configuration printed on the radiator shroud for a 5.9l cummins...
                -John Adams, 1735-1826-
                • F
                  F
                  Fitzy
                  Most of the big power diesels are stock blocks just head studs and headgaskets.
                  2002 Honda S2000
                  2006 Dodge Ram CTD
                  • K
                    K
                    There are 2 trucks in the area that I know about that have built motors with a bunch of goodies.
                    You can make power really really quick for a cheaper price on a diesel then a gas truck(chip, intake, exhaust). But when you want to start going for the like 500ish+ it get extremely expensive extremely fast. I know modding anything is expensive especailly when going for lots of power. You have to remember diesels dont rev near as high as gas motors so it takes more of the factors that gain power then other cars.
                    • 2gTSIGUY2
                      2gTSIGUY2
                      2gTSIGUY
                      Anyone know if he was running propane in that rig?
                      • K
                        K
                        ^It would not suprise me.
                        I talked to my dad, he said both the hardcore modded trucks in the area are running fully built motors(custom built injection pumps, camshafts....) one is 630whp and the other is 718whp. He also said even at that level you need a built motor.
                        • zbrownZ
                          zbrownZ
                          that is the same motor used in the 3/4 and 1 ton 12 valve dodges.... (94-98.5)
                          the first gen motors (89-93) were nearly identical cept small changes like the position of the top piston ring and they didnt use an inline Bosh pump like the 2nd 12 valve pickups did, they used a rotary style pump
                          In 98.5 they switched to the 24 valve which is essentially the same block with a 24valve head and different fueling
                          and i would not be suprised in the least if that is a stock block .... at all
                          usually what is done is flow work on the head and O-ringing the head, and studs
                          do you realize how easy it is to get 800hp/1200fts + out of a 12 valve or 24 valve?? the problem is building your drivetrain to sustain this
                          once more is learned about the common rail system the power potential will be that much more
                          stock equipment in the f650 and a 3/4 ton dodge...... seems like an easy choice:icon_scratch:
                          • zbrownZ
                            zbrownZ
                            uhh i def dont know about that..... i read religiously on a hardcore cummins forum.... and 450 is no problem even on a tiny ass 9cm2 hx35
                            my pickup would be at 550 wheel easily with a set of injectors, delivery valves, and governor springs and no head work or anytyhing... i cant do this becasue the converter and trany will not support the TQ created
                            • zbrownZ
                              zbrownZ
                              yes he is exactly correct....+ oringed head
                              sorry got excited a little... but that is the other thing i like aside from rotarys..... mechanical pump cummins
                              • JoelJ
                                JoelJ
                                hahaha zach on his tangents
                                • MisterCMKM
                                  MisterCMKM
                                  What kind of truck do you have?
                                  thrash;315544 wrote:
                                  Ford is back :)
                                  • P
                                    P
                                    Typically the 24 valves are putting down 425-460hp and 800-860 ft lbs w/ just a programmer and exhaust.
                                    I ran my truck twice last year stock 16.3, programmer and exhaust 14.7. 7200lbs w/ me in it, definate drastic power increase w/ minimal mods.
                                    • zbrownZ
                                      zbrownZ
                                      a 95 12valve with 5" exhaust and fuel plate
