  4. Throwing code 16, EGR valve code, help
19 Posts 12 Posters 755 Views
    egr is overrated
      Clean it out and resolve the code.
      • D S ohMD Offline
        D S ohMD Offline
        D S ohM
        Screw the EGR. I run blockoff plates in mine.
        I wanna go fast!
          wannabe;184613 wrote:
          16 EGR Valve Position Sensor
          Get a new sensor then....it's a seperate part than the valve
            on the ford probe the egr only is working when at idle and cruiseing speeds. so it is shut off when full throttle. so all you would be doing is ruining your gas mileage.
            just do what hjermy said and clean that bitch.
            • ruthless351R Offline
              ruthless351
              start there and keep us updated^^^^^
                idk if this is some kind of super sweet dsm power trick or whatever but this doesnt sound like a good idea to me, unless you tune for it well. egr keeps cylinder temps down to prevent detonation and help gas mileage.
                • Turbo5OhT Offline
                  Turbo5OhT Offline
                  Turbo5Oh
                  wow egr prevents detonation? i didnt know dumping hot exhuast gas back into the intake cooled the intake charge
                  run a egr block off plate myself, removing the egr will not affect any driveability at all. it will depend on the set up if it will trow codes or not. is the egr all in 1 or does it have egr,regulator, sensor set up? u'll have to do some research on how to trick the module into turning the light of
                    there are guys on probetalk that have had there gas mileage go down like 10 mpg on average, by removing the egr. it isn't worth it unless your going big turbo and standalone ems.
                    seriously tell me how this helps a car with bolt on's and still on a stock tiny turbo?
                      all exhaust gas is is spent fuel and air that cant be burned anymore. by putting that back into the cc and basically acting like a space filler that cant be burned it essentially decreases the volume of the cc with "cooler" air that is not burning. it improves gas mileage by basically decreasing its displacemnt when its working. on probes it only works at idle and low rpm...thus making fuel mileage WORSE when taking it off. why do you think they put it on cars in the first place?
                      • Turbo5OhT Offline
                        Turbo5OhT Offline
                        Turbo5Oh
                        this one time i read that this one guy made like umpteen more hp by removing the egr system!
                        do/read what u want, done right it will do more good then bad
                        • GarageAlchemistG Offline
                          GarageAlchemist
                          EGR came out in what? the 70's? then we had a fuel crisis, go figure huh? Goverment conspiracy # 232233
                          97 GTi, 03 KJ
                          • ticklemedalyT Offline
                            ticklemedaly
                            EGR lesson #101
                            http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
                            XBL G-tag: TickleMeDaly83
