  4. Throwing code 16, EGR valve code, help
19 Posts 12 Posters 630 Views
    Clean it out and resolve the code.
    • D S ohMD Offline
      D S ohMD Offline
      D S ohM
      Screw the EGR. I run blockoff plates in mine.
      I wanna go fast!
        wannabe;184613 wrote:
        16 EGR Valve Position Sensor
        Get a new sensor then....it's a seperate part than the valve
          on the ford probe the egr only is working when at idle and cruiseing speeds. so it is shut off when full throttle. so all you would be doing is ruining your gas mileage.
          just do what hjermy said and clean that bitch.
          • ruthless351R Offline
            ruthless351
            start there and keep us updated^^^^^
              idk if this is some kind of super sweet dsm power trick or whatever but this doesnt sound like a good idea to me, unless you tune for it well. egr keeps cylinder temps down to prevent detonation and help gas mileage.
              • Turbo5OhT Offline
                Turbo5OhT Offline
                Turbo5Oh
                wow egr prevents detonation? i didnt know dumping hot exhuast gas back into the intake cooled the intake charge
                run a egr block off plate myself, removing the egr will not affect any driveability at all. it will depend on the set up if it will trow codes or not. is the egr all in 1 or does it have egr,regulator, sensor set up? u'll have to do some research on how to trick the module into turning the light of
                  there are guys on probetalk that have had there gas mileage go down like 10 mpg on average, by removing the egr. it isn't worth it unless your going big turbo and standalone ems.
                  seriously tell me how this helps a car with bolt on's and still on a stock tiny turbo?
                    all exhaust gas is is spent fuel and air that cant be burned anymore. by putting that back into the cc and basically acting like a space filler that cant be burned it essentially decreases the volume of the cc with "cooler" air that is not burning. it improves gas mileage by basically decreasing its displacemnt when its working. on probes it only works at idle and low rpm...thus making fuel mileage WORSE when taking it off. why do you think they put it on cars in the first place?
                    • Turbo5OhT Offline
                      Turbo5OhT Offline
                      Turbo5Oh
                      this one time i read that this one guy made like umpteen more hp by removing the egr system!
                      do/read what u want, done right it will do more good then bad
                      • GarageAlchemistG Offline
                        GarageAlchemist
                        EGR came out in what? the 70's? then we had a fuel crisis, go figure huh? Goverment conspiracy # 232233
                        97 GTi, 03 KJ
                        • ticklemedalyT Offline
                          ticklemedaly
                          EGR lesson #101
                          http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
                          XBL G-tag: TickleMeDaly83
