  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
  • capitljC Offline
    capitljC Offline
    capitlj
    VTEC? lol
    There is always more power out there but I've never driven anything with more than 550 so ummm yeah
    > Mitch Hedberg wrote:
    2004 Impala LS 3.8
      I've never been in a car with remotely close to that power must be sweet!
      • XJHEADX Offline
        XJHEADX Offline
        Running out of fuel now
        • M Offline
          M Offline
          musthavemuzk
          well that sux
          Monty
          14.59 at 94.85 still stock
          www.pbase.com/musthavemuzk
            Fuel problem solved, that thing needs a LOT of fuel.
              what was up?
              • M Offline
                M Offline
                musthavemuzk
                alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                Monty
                  Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
                    So..... How many GPM of fuel are being pumped?
                    • XJHEADX Offline
                      XJHEADX Offline
                      Dave's is rated at about 200 gallons per hour, mine is rated at about 840 Lbs/hour or 124 glns/hour. With each connected separately they each lost pressure at about the same time. Had to add a new return port on the tank and removed fitting where the old return was installed and hooked Dave's into there. Looks sorta funny with 2 -10's up front..
                      It will be at Straight Line Detailing/Straight Line Specialties later this week for a good cleaning if anyone wants to take a look. NO TOUCHING, it is a ticking time bomb right now:eek:
                      • M Offline
                        M Offline
                        musthavemuzk
                        i see
                        i knew E85 needed more fuel....did not realize thst much more.
                        Monty
