  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
    IMO you got a bottlekneck still somewhere from looking @ the graphs and how each boost level follows the same curve.
    You gonna get another cam coming? Swap out that intake if Andy has that other one, got nothing to lose.
      94NDTA;186779 wrote:
      I think you have the highest rwhp of anyone on this site.
      you think?
      • EvanE Offline
        EvanE Offline
        Evan
        Congrats on the numbers. nice car too.
        > bubba;204638 wrote:
        <u>Past Rides:</u>
        -2003 Dr-Z 125-Sold
        <u>Current Rides:</u>
        • XJHEADX Offline
          XJHEADX Offline
          Going back to the dyno again this week. I made another change. This is starting to get old....Need to wake these turbos up, they are still pretty lazy...
          • XJHEADX Offline
            XJHEADX Offline
            Got back on tues night with some new numbers. I did a cam change over the W/end. Thanx for the help MisterCMK:p: . Anyways final number was 1150 RWHP. Need to clean the pig up and save it for SEMA at the end of the month. Hopefully be in the top 5 with these numbers..
            • M Offline
              M Offline
              musthavemuzk
              good luck!!
              Monty
              14.59 at 94.85 still stock
              www.pbase.com/musthavemuzk
                probe this
                4 valve heads? more boost? bigger turbo? NITROUS!!!
                Not sure what all you have done, but some things to look at.
                My probe is fast. How fast? Line up next to me at the track and find out.
                I can pull my probe faster than most ricers can race. haha
                99 black lightning 496whp, 620ft/lbs heavy pig
                • XJHEADX Offline
                  XJHEADX Offline
                  probe this;188769 wrote:
                  4 valve heads? .
                  Not available
                  more boost?.
                  Running plenty, doesn't like more
                  bigger turbo's?.
                  Big enough
                  NITROUS!!!.
                  Thought about it
                  Pretty much everything.
                  • capitljC Offline
                    capitljC Offline
                    capitlj
                    VTEC? lol
                    There is always more power out there but I've never driven anything with more than 550 so ummm yeah
                    > Mitch Hedberg wrote:
                    2004 Impala LS 3.8
                      I've never been in a car with remotely close to that power must be sweet!
                      • XJHEADX Offline
                        XJHEADX Offline
                        Running out of fuel now
                        • M Offline
                          M Offline
                          musthavemuzk
                          well that sux
                          Monty
                            Fuel problem solved, that thing needs a LOT of fuel.
                              what was up?
                              • M Offline
                                M Offline
                                musthavemuzk
                                alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                                as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                                Monty
                                  Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
                                    So..... How many GPM of fuel are being pumped?
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      Dave's is rated at about 200 gallons per hour, mine is rated at about 840 Lbs/hour or 124 glns/hour. With each connected separately they each lost pressure at about the same time. Had to add a new return port on the tank and removed fitting where the old return was installed and hooked Dave's into there. Looks sorta funny with 2 -10's up front..
                                      It will be at Straight Line Detailing/Straight Line Specialties later this week for a good cleaning if anyone wants to take a look. NO TOUCHING, it is a ticking time bomb right now:eek:
                                      • M Offline
                                        M Offline
                                        musthavemuzk
                                        i see
                                        i knew E85 needed more fuel....did not realize thst much more.
                                        Monty
