  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    I think you have the highest rwhp of anyone on this site.
      Did you swap out the valve springs yet?
      • XJHEADX Offline
        XJHEADX Offline
        Yep did that before the tangs were put in. Back pressure with new housings and 4" dual is only at 1.1 - 1 backpresure ratio.
          IMO you got a bottlekneck still somewhere from looking @ the graphs and how each boost level follows the same curve.
          You gonna get another cam coming? Swap out that intake if Andy has that other one, got nothing to lose.
            you think?
            • EvanE Offline
              EvanE Offline
              Evan
              Congrats on the numbers. nice car too.
              > bubba;204638 wrote:
              <u>Past Rides:</u>
              -2003 Dr-Z 125-Sold
              <u>Current Rides:</u>
              • XJHEADX Offline
                XJHEADX Offline
                Going back to the dyno again this week. I made another change. This is starting to get old....Need to wake these turbos up, they are still pretty lazy...
                • XJHEADX Offline
                  XJHEADX Offline
                  Got back on tues night with some new numbers. I did a cam change over the W/end. Thanx for the help MisterCMK:p: . Anyways final number was 1150 RWHP. Need to clean the pig up and save it for SEMA at the end of the month. Hopefully be in the top 5 with these numbers..
                  • M Offline
                    M Offline
                    musthavemuzk
                    good luck!!
                    Monty
                    14.59 at 94.85 still stock
                    www.pbase.com/musthavemuzk
                      probe this
                      4 valve heads? more boost? bigger turbo? NITROUS!!!
                      Not sure what all you have done, but some things to look at.
                      My probe is fast. How fast? Line up next to me at the track and find out.
                      I can pull my probe faster than most ricers can race. haha
                      99 black lightning 496whp, 620ft/lbs heavy pig
                      • XJHEADX Offline
                        XJHEADX Offline
                        probe this;188769 wrote:
                        4 valve heads? .
                        Not available
                        more boost?.
                        Running plenty, doesn't like more
                        bigger turbo's?.
                        Big enough
                        NITROUS!!!.
                        Thought about it
                        Pretty much everything.
                        • capitljC Offline
                          capitljC Offline
                          capitlj
                          VTEC? lol
                          There is always more power out there but I've never driven anything with more than 550 so ummm yeah
                          > Mitch Hedberg wrote:
                          2004 Impala LS 3.8
                            I've never been in a car with remotely close to that power must be sweet!
                            • XJHEADX Offline
                              XJHEADX Offline
                              Running out of fuel now
                              • M Offline
                                M Offline
                                musthavemuzk
                                well that sux
                                Monty
                                  Fuel problem solved, that thing needs a LOT of fuel.
                                    what was up?
                                    • M Offline
                                      M Offline
                                      musthavemuzk
                                      alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                                      as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                                      Monty
                                        Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
                                          So..... How many GPM of fuel are being pumped?
