  4. Latest Dyno run
Latest Dyno run
32 Posts 17 Posters 1.8k Views
    probe this
    4 valve heads? more boost? bigger turbo? NITROUS!!!
    Not sure what all you have done, but some things to look at.
    My probe is fast. How fast? Line up next to me at the track and find out.
    I can pull my probe faster than most ricers can race. haha
    99 black lightning 496whp, 620ft/lbs heavy pig
    • XJHEADX Offline
      XJHEADX Offline
      probe this;188769 wrote:
      4 valve heads? .
      Not available
      more boost?.
      Running plenty, doesn't like more
      bigger turbo's?.
      Big enough
      NITROUS!!!.
      Thought about it
      Pretty much everything.
      • capitljC Offline
        capitljC Offline
        capitlj
        VTEC? lol
        There is always more power out there but I've never driven anything with more than 550 so ummm yeah
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          I've never been in a car with remotely close to that power must be sweet!
          • XJHEADX Offline
            XJHEADX Offline
            Running out of fuel now
            • M Offline
              M Offline
              musthavemuzk
              well that sux
              Monty
              14.59 at 94.85 still stock
              www.pbase.com/musthavemuzk
                Fuel problem solved, that thing needs a LOT of fuel.
                  what was up?
                  • M Offline
                    M Offline
                    musthavemuzk
                    alot as in more than the 2jz you, Matt or that GS300 run? or similar?
                    as i remember Matt talking about running 3 fuel pumps to supply enough fuel for his. at least i think he said 3. mayb it was the GS300 that ran 3.
                    Monty
                      Bill runs E85, so he needs about 30% more fuel than if he were using gasoline. He was out of fuel pump. He put on my Weldon and that still wasn't enough. Now he has his pump and my Weldon both running in parallel.
                        So..... How many GPM of fuel are being pumped?
                        • XJHEADX Offline
                          XJHEADX Offline
                          Dave's is rated at about 200 gallons per hour, mine is rated at about 840 Lbs/hour or 124 glns/hour. With each connected separately they each lost pressure at about the same time. Had to add a new return port on the tank and removed fitting where the old return was installed and hooked Dave's into there. Looks sorta funny with 2 -10's up front..
                          It will be at Straight Line Detailing/Straight Line Specialties later this week for a good cleaning if anyone wants to take a look. NO TOUCHING, it is a ticking time bomb right now:eek:
                          • M Offline
                            M Offline
                            musthavemuzk
                            i see
                            i knew E85 needed more fuel....did not realize thst much more.
                            Monty
